magyarbacsi
- Joined
- Sep 8, 2007
- Messages
- 110
I recently did my 50 hr tranny/hydraulic fluid change on my 5525 that is 2yrs old, used NAPA premium tractor fluid that my dealer recommended. I changed the filter, but did not remove the strainer that is in the bottom of the tranny becuse it looked like I would have to remove some lincs and becuse of a custom frame for the Bradco backhoe, some of the frame members. Has anyonr removed this screen and cleaned it and if so, what problems if any did you encounter. Are there seals or such that I need on the housing that will need to be replaced?
The fluid that I drained actually looked clean and I did not find any meta shavings or scum, so can I expect that the screen is ok? The tractor/hydraulics work ok, except the bh bucket is slow to open. It clamps fast and holds and every other function is good.
