Results 1 to 6 of 6
  1. #1
    Bronze Member Blue_Sky's Avatar
    Join Date
    Oct 2009
    Posts
    87
    Lower Alabama
    2006 2615 4WD Mahindra
    Default 2615 3pt hitch hydralics
    The 3 pt hitch hydralics on my 2615 Mahindra tractor stopped working this afternoon. It is stuck in the up position. The lever which raises and lowers the 3 pt hich mechanism will move but with some difficulty but the hitch remains in the up position. Any ideas or suggestions. Thank you for your assistance.
  2. #2
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,142
    Central Square, NY
    LS XR3037HC
    Default Re: 2615 3pt hitch hydralics
    First thing to check is the speed control knob located straight down from the front of your seat. If the knob is closed (fully clockwise) the 3 pt. won't lower. If it is closed, turn it to the left. It controls the speed at which the 3 pt. lowers.
    As to the linkage, it requires a good spray with penetrating lube several times a year (at least mine does) to keep them moving freely.
  3. #3
    Join Date
    Mar 2010
    Posts
    169
    Bayboro NC
    Mahindra 4035
    I agree with George 2615 i had to spray wd 40 on my levers where they go into the casing and you need to check the lowering knob. What were you doing when it quit working
  4. #4
    Join Date
    Oct 2009
    Posts
    87
    Lower Alabama
    I had been using a middle breaking plow and I did not lower it all the way down that night. The next day the 3 pt. hitch was stuck in the up position and would not come down. I took a come-a-long and attached one end to the ROPS - put a chain on the arms and lifted it up as far as I could. I was thinking that a valve was stuck and this would take the pressure off and the unit would lower. This did not work. I then took the seat and metal plates off and found a lot of dirt there. I cleaned the dirt off and then blew it off using the air compressor. I repeated this procedure a couple of times, paying special attention to the moving part areas. I took some WD40 and liberally sprayed the moving part areas. I began working the lever and the 3 pt. hitch began moving like it did when it was new. I am eventually going to replace the lever - it is slightly bent - it works fine but I will replace it sometime.
  5. #5
    Platinum Member jpm1's Avatar
    Join Date
    Feb 2008
    Posts
    590
    Panther Lake, Oswego County New York
    Mahindra 2810 HST, Kioti DK35SE HST
    I agree with George 100 percent! Chech the speed lowering knob. My Mahindra is slow to turn itself off unlike my Kioti, don't back the knob out past the resistance felt, it will come apart and then the "Fun begins" I don't know why it turns itself in but mind does. Dealer can't explain it ither. . .John
    Lord, Help me to be the man my dog thinks i am . . .John. Mahindra 2810HST, 108H loader with Quick tach buckets and forks. Kioti DK35SE HST with loader, Hyd. top link and second set of rear remotes, 60" and 66" buckets, Kubota 900 RTV and a bunch of other good stuff
    Buy more equipment, It makes life easier.!
  6. #6
    Join Date
    Feb 2005
    Posts
    8,142
    Central Square, NY
    LS XR3037HC
    Quote Originally Posted by jpm1 View Post
    Mine actually has a locking nut on the threads so once the down speed is set it can be locked in place.
Similar Threads
  1. is there a drawbar lock for telescoping 3pt arms
    By dirtbikekid1090 in forum Attachments
    Last Post: 02-17-2017, 10:33 PM
  2. Standard L series owners POST YOUR SMOOTH 3PT HITCH VIDS HERE
    By jokergerm in forum Kubota Owning/Operating
    Last Post: 08-22-2011, 03:36 PM
  3. New GC2410 3pt. hitch hydrolics issue
    By fozzy in forum Massey Ferguson Owning/Operating
    Last Post: 06-08-2011, 12:46 PM
  4. Sleeve Hitch to Cat. 0 -3pt adapter
    By gbprather in forum Attachments
    Last Post: 04-02-2011, 07:54 PM
  5. My thoughts on L series jerky 3pt hitch, don't regret purchase
    By Robert6401 in forum Kubota Owning/Operating
    Last Post: 04-02-2009, 08:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
