HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-21-2003, 07:05 PM   #1 (permalink)
cjw
Default small complaint
I needed to clean the radiator screen on my tractor & discovered I needed to remove the loader to get the screen off all the way. The loader was surprisingly easy to remove.
Here is a picture of my 2800 without the loader.
cjw is offline   Reply With Quote
Old 05-21-2003, 07:06 PM   #2 (permalink)
cjw
Default Re: small complaint
here is a picture from a different angle
Old 05-21-2003, 07:14 PM   #3 (permalink)
I'm sure your method is more "complete" - but I use compressed air to blow out the radiator screen on my 4110. Been a while since I've been near a 2810 so I'm not sure on the clearances and such, but it seems like you may be able to do the same thing so you don't have to remove your FEL. Granted, it takes me a little stretching & contorting [img]/forums/images/graemlins/crazy.gif[/img], but only takes a few minutes. Perhaps you can get an extended “wand” so you wouldn’t have to contort so much. (Hey, maybe I’ll do that too instead of using the short version I currently have! [img]/forums/images/graemlins/tongue.gif[/img])
RanchMan is offline   Reply With Quote
Old 05-21-2003, 07:40 PM   #4 (permalink)
That sure is a good-looking tractor without the loader on it [img]/forums/images/graemlins/smirk.gif[/img]
Mark
markie61 is offline   Reply With Quote
Old 05-22-2003, 09:37 AM   #5 (permalink)
I second your complaint! That is one of the few things I've found that I consider a true design flaw - they could have easily made the screen slide straight up for removal instead of to the side.
I am glad to hear the FEL was easy to remove. I've been thinking about removing mine just to reduce the weight for mowing around my yard and make it easier to maneuver around my wooded areas.
OkieNCognito is offline   Reply With Quote
Old 05-22-2003, 10:06 AM   #6 (permalink)
<font color="blue">they could have easily made the screen slide straight up for removal instead of to the side. </font>
Help me understand here - are you saying you have to remove your FEL to remove your side panels or am I just misunderstanding what you are saying?
Old 05-23-2003, 09:35 AM   #7 (permalink)
The side panels will come off with the FEL attached - it's the screen in front of the radiator that won't slide out with the FEL attached. It will slide out about six inches and then hits the arm on the FEL.
Your extended wand idea should work.
Old 05-23-2003, 06:55 PM   #8 (permalink)
</font><font color="blue" class="small">( The side panels will come off with the FEL attached - it's the screen in front of the radiator that won't slide out with the FEL attached. It will slide out about six inches and then hits the arm on the Fel. )</font>
Just raise the loader to where the screen will come out !!
DK35vince is offline   Reply With Quote
Old 05-23-2003, 07:35 PM   #9 (permalink)
</font><font color="blue" class="small">( Just raise the loader to where the screen will come out !! )</font>
Never never get under a raised loader or any of its components!!!! I refer to this link and other stories......
Mark
Old 05-24-2003, 01:35 AM   #10 (permalink)
My DK 35 is the same way.
The screen hits the loader arm.
When I need to clean the screen I lift the loader to where the screen can come out reach under the arm and pull out the screen.
You are not working under the loader and if the loader would fall your arm and hand has plenty of roon under the arms as not to get pinched !
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
