Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    11
    Prairieville, Louisiana
    None
    Default 4035 Weight
    Looking at buying a Mahindra 4035 and concerned about hauling the tractor with my truck. I have a half ton Chevy with a 5.3 and a 16 foot tandum axel trailer with 3500# axels. Would like to hear from some 4035 owners. Thanks
  2. #2
    Gold Member
    Join Date
    May 2012
    Posts
    486
    NW Louisiana
    MF 35, Mahindra 4035
    Default Re: 4035 Weight
    I'm looking at a 4035 as well.... Talked to my dealer(Scott's Tractor)and he said I should not have any problems. I'll be towing 16' tandem with 3500 lb axels, 4035 with FEL and MD bushhog...towing with a Chvy Avalanche... Dealer did kinda chuckle and tell me " you'll definitely know its bak there !". He also told me to make sure my trailer tires are "trailer tires" and not car tires put on a trailer...( I have brand new 8 ply "trailer tires) n just BTW I'll tow about 150 miles to deer lease about twice a year which will be the VAST majority of my toeing endeavors ! Lol !
  3. #3
    Gold Member
    Join Date
    Sep 2007
    Posts
    323
    Texas
    Mahindra 2810, IH Hydro 70, 706
    according to the pdf a hst 4035 weights 4800 lbs, just the tractor. Add more for FEL, loaded rears, 3pt.
    our 16ft tandem w/ 3500lb axles weights about 1300 lbs empty.
    So yeah you will be maxed if not a little overweight... like the dealer said good tires are a must. I air up to max air pressure or 2 or 3 psi under max (in case my gauge is off) to... remember that tire load ratings are @ the max PSI.
  4. #4
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,048
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by JHubbs View Post
    You buying and want to trailer JUST the tractor???? OR are you getting it with a FEL and implements??
    4800# for just tractor is going to put you @ ~6500# with a loader. No implements and you are already overweight.
    Length is going to be your other issue. 16' is too small. I have a 20' trailer and it is all I can do to get my SMALLER 3400 with loader and bushhog on. I actually have to back on the trailer and set the tailwheel on the tongue of the trailer about a foot behind the hitch just to make it fit.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  5. #5
    Gold Member
    Join Date
    May 2012
    Posts
    486
    NW Louisiana
    Yeah, I know I'm either maxed or close to maxed...16' really is too short, my cutter over hangs and I have to hang the red caution flag off the cutter wheel...I too max on air pressure...when towing, I just take it slow, pull over from time to time and check everything (also to let faster traffic by)...wish I had a bit bigger trailer...IMHO a 5th wheel/goose neck deck over is the way to go if you're going to trailer alot or for long distances...having said that, I will stick with what I've got for now...
    either way, good luck, be safe
    Rich
  6. #6
    New Member
    Join Date
    May 2012
    Posts
    11
    None
    Yes, I was looking at the 4035 with a FEL. Just left the dealership and all they had was a 5035 with no FEL. Tractor had a little bit more plastic than I was hoping for. The weight issue looks like it may be a problem as well. Just don't feel safe being over the limit and dont want to spend the extra money on a new trailer and truck right now. I guess the search continues. Thanks everyone for the input.
  7. #7
    Gold Member
    Join Date
    May 2012
    Posts
    486
    NW Louisiana
    Scott's tractor in Shreveport has a 4035 gear with FEL in case you're still looking....know it is a haul from where you're at though...maybe Scott's would work something with your dealer ?
  8. #8
    Bronze Member Chris 3055's Avatar
    Join Date
    Mar 2012
    Posts
    51
    Adirondack Mountains, NY
    Mahindra 4035
    I was looking into a trailer to move my 4035 around. I want to go with a 10,000lb trailer. Dual axle. Need a category III hitch put on, the cat II that comes on the truck won't cut the weight. Don't forget that when you do your calulations that you need to subtract the weiight of the trailer from your total, or add it in to your total weight calculations.
    So, 4800 lb tractor+FEL+loaded tires+trailer weight(about 1600lbs)= X
    It adds up quick... Then you have to worry about trailer brake laws for your state. Here in NY I need them on teh dual axle trailer. WOuld want them any way with all that weight behind me.
    - Chris
  9. #9
    New Member
    Join Date
    May 2012
    Posts
    11
    None
    Default
    The 4035 is just going to be too much weight for my ltruck and trailer. Forums like this help people get a better understanding of what they want and being pleased with their purchase. Thanks Tbn members
  10. #10
    New Member
    Join Date
    Oct 2011
    Posts
    20
    Gig Harbor, WA
    Mahindra 4035
    The dealer won't deliver?
Similar Threads
  1. Trailer weight question
    By General Lee in forum Trailers & Transportation
    Last Post: 04-14-2011, 10:54 PM
  2. Too much Weight in the Weight Box?
    By captplaid in forum John Deere Lawn & Garden
    Last Post: 12-23-2010, 04:05 PM
  3. FMCSA interpretation of GCWR
    By Duffster in forum Trailers & Transportation
    Last Post: 09-10-2010, 06:43 PM
  4. weight of trailer, tractor and truck
    By heehaw in forum Rural Living
    Last Post: 04-07-2008, 06:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
