Results 1 to 5 of 5
06-24-2012, 12:39 PM #1New Member
- Join Date
- Sep 2011
- Posts
- 14
- Tractor
- Mahindra 2516HST
2516 fuel shutoff valve
Anyone know where the fuel shutoff valve is on a Mahindra 2516hst? I have a new fuel filter and of course the manual says to shut off the fuel line but it does not show where it is. Usually it is right where the filter is, where the lines all come in but there is no screw there or anything. The second I loosen up the filter cup fuel pours out so I assume the must be a shutoff someplace.
Thanks
06-24-2012, 11:43 PM #2New Member
- Join Date
- Mar 2010
- Posts
- 14
- Location
- western pa
- Tractor
- mahindra 2516 hst
Re: 2516 fuel shutoff valve
On Mine The fuel stops when I remove the filter. Some fuel come out but stops.
06-25-2012, 01:32 PM #3Platinum Member
- Join Date
- May 2002
- Posts
- 740
- Location
- Close to Petersburg
- Tractor
- Mahindra 2516
Same. Take off the filter, prefill it and good to go.
06-25-2012, 07:27 PM #4New Member
- Join Date
- Sep 2011
- Posts
- 14
- Tractor
- Mahindra 2516HST
Thanks guys :-). I'll give it a go this weekend. Just seemed to really pour fuel when I had loosened it up.
06-27-2012, 01:02 PM #5Silver Member
Approved Advertiser
- Join Date
- Nov 2002
- Posts
- 267
- Location
- Bethany, CT
- Tractor
- Mahindra's
It will shut off as said when you unscrew the bowl and re bleed when you put the new one in. *** But make sure when you put the new filter in you swap or replace the tiny o-ring in the center of the filter. I would recomend a new one but if not look inside the old filter pull it out and swap it into the new filter.
Similar Threads
Oil & Fuel fuel shutoff in l2500
By jimbo64 in forum Kubota Owning/OperatingReplies: 10Last Post: 10-08-2009, 12:25 PM -
Oil & Fuel kubota G1800 fuel shutoff
By ashcraft in forum Kubota Owning/OperatingReplies: 1Last Post: 09-15-2006, 05:25 PM -
By ashcraft in forum Kubota Lawn & GardenReplies: 1Last Post: 09-15-2006, 05:25 PM -
Oil & Fuel Z-Force 44 Fuel Shutoff Valve
By ibjim in forum Cub Cadet Yanmar & CUTsReplies: 4Last Post: 05-23-2005, 09:49 PM -
Oil & Fuel leaky fuel shutoff
By Anderson in forum Kubota Owning/OperatingReplies: 6Last Post: 04-10-2001, 05:07 PM
