Page 5 of 6 FirstFirst ... 23456 LastLast
Results 41 to 50 of 54
  1. #41
    Bronze Member MahindraDon's Avatar
    Join Date
    Mar 2012
    Posts
    82
    Dunn, NC
    Mahindra
    Default Re: mahindra quality
    There is one in front of the radiator and one behind, which may be in front of A/C condensor. I'm not sure exactly because I don't have any left in stock. I'll try to track down some information and get back to you.
  2. #42
    Gold Member
    Join Date
    Nov 2009
    Posts
    473
    Just an update on my posting here. I had some 4wd engagement problems. I took the tractor to a dealer I have used some years ago but does not carry the Mahindra brand. I brought it in on Tues at 200PM. He said they were busy with getting equipment ready for harvest and the Farm Science Review. I said I understood and there was no real hurry at this point. He called today, less than 24 hours later to say it was done.
    They added an interior fan, again blew out the radiator, condenser, evaporator and found that the drive shat coupler's snap ring was not installed which allowed the coupler to back off. All done for under $200 in less than 24 hours for a tractor brand they do not normally work on. Also the labor charge was $11 an hour less than the 9 week painful experience I had earlier with a different dealer. Happy today on this.
  3. #43
    Join Date
    May 2012
    Posts
    2,199
    Me
    Mahindra Max28XL HST
    Default
    Quote Originally Posted by yanmars
    That is great! I think that dealer deserves a "plug" here on TBN, with location and contact info and weblink, if available.
    http://www.ohr.edu/838
    https://www.youtube.com/watch?v=U9BfhxL_JTI
    https://www.youtube.com/watch?v=J8UEVoSJmfs
    “If you continue in My word, then you are truly disciples of Mine;and you will know the truth, and the truth will make you free.” Ancient of Days
    My soul finds rest in God alone; my salvation comes from him.
    http://www.youtube.com/watch?v=37aM75LaEDk&list=PLGLwt3_lSbxxRtjMLHJDpqEK 9vcq9IfsJ
    t
  4. #44
    Veteran Member kneedeep's Avatar
    Join Date
    Apr 2012
    Posts
    1,068
    Central AL & MS Delta
    Mahindra 3510 and Mahindra 8560 Cab 4WD
    Default Question for Daves Tractors
    For Dave-
    If a radiator was built for a 3510-
    What would be the best specs for fin spacing, # of cores, size , etc. to make it work better in a dusty environment such as bushhogging tall weeds??
    PROUD AIR FORCE DAD
  5. #45
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,253
    Red Bluff, CA
    Changes often!
    Default Re: Question for Daves Tractors
    Quote Originally Posted by kneedeep View Post
    For Dave-
    Kneedeep, I have wondered the same thing. I had an old Ford 5000 that I mowed with for years. I ran a 10' flail and mowed 10 acres (irrigated) every few weeks. I could go several years neglecting the radiator and it would not clog enough to start running warm. Since my orchard/park are irrigated, I get way less junk in the radiator compared to mowing tall weeds, but I was impressed with the neglect the radiator would handle. I wish that old tractor was still here and I'd go out and measure up the core.
    I am totally guessing on this, but it would seem that the grill catches the large stuff and the radiator fins on your 10-series are about the perfect size to catch the small stuff that makes it through the grill. If the fins were wider, would that crud pass through? Wider fins create a less efficient radiator, so a bigger core would be needed.
    Some industrial tractors have a reversing fan. Every so often the blade pitch swings nearly 180 degrees and blows out the radiator. Now wouldn't that be cool, pun intended? I suspect if such a fan blade system were designed for smaller tractors like ours, there would be a market for it.
    Dave
    Dave's Tractor, Inc.
    Red Bluff, California
  6. #46
    Join Date
    Apr 2012
    Posts
    1,068
    Kinda like these-
    TractorLife.com: For Max Efficiency, Keep Radiators Clean With Reversible Fans
    CLEANFIX
    If these were made for compact tractors, I believe a small fortune could be made!!
    PROUD AIR FORCE DAD
  7. #47
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,253
    Red Bluff, CA
    Changes often!
    Kinda like these-
    CLEANFIX
    Yep, that is perfect. If I was mowing in dry stuff and had to clean the radiator several times a day and/or risk engine damage from overheating, I'd pay a bunch for one of these installed. Anybody know how much they cost for the smallest one?
    Dave
  8. #48
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Needs a air compressor to work.
    Murph
  9. #49
    Join Date
    Apr 2012
    Posts
    1,068
    Quote Originally Posted by murphy1244 View Post
    Yeah- mine needs one too!!!
    Attached Thumbnails Attached Thumbnails mahindra quality-blow-gun1-jpg   mahindra quality-blow-gun-jpg
    PROUD AIR FORCE DAD
  10. #50
    New Member
    Join Date
    Apr 2012
    Posts
    1
    Thomasburg , Ontario - Canada
    2012 mahindra 8560
    I treated myself to a new mahindra 8560 4wd. half a year ago and I am still jealous of myself ! Had a john deere 2130 , don't miss it one bit ! for half the price of a new john deere built in the same place with the same engine , you get more tractor , twice as much warranty , no plastic fenders and hood but fat , solid steel ,turns on a dime , after 250 hours I can recommend this tractor to everyone !! and my dealer , Bob Mark in Campbellford-Ontario is great..something wrong , they come right away , if they cant solve it , you get another tractor to use . So far the pto broke , seemed I was the first case ever ...just found the seat to low so raised it 3 inches , gave me better vieuw too... and I put a headlight guard on after breaking one with a stick . why buy a 4-5 year old tractor with 3-4000 hours on it and no warranty , if the same money buys you a great new mahindra ??? RECOMMENDED !!!!!! Lionmahindra quality-plow-1-jpg
Similar Threads
  1. Buying Advice Mahindra Quality questions
    By Surgeon in forum Mahindra Buying/Pricing
    Last Post: 12-19-2011, 10:24 AM
  2. Mahindra 2525 quality check.
    By Sweden-Art in forum Mahindra Buying/Pricing
    Last Post: 04-14-2010, 01:32 PM
  3. Mahindra wins Japanese Quality Award
    By DavesTractor in forum Mahindra Owning/Operating
    Last Post: 11-08-2007, 02:38 PM
  4. Mahindra Tractors Quality and Reliability?
    By Stoner in forum Mahindra Owning/Operating
    Last Post: 08-31-2007, 05:18 PM
  5. Mahindra & Mahindra Vehicle Assembly Line
    By AchingBack in forum Mahindra Owning/Operating
    Last Post: 06-23-2007, 12:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
