Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 51
  1. #11
    Join Date
    Feb 2012
    Posts
    586
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    Default Re: Mahindra Battery Terminal Corrosion
    Get the quality ends that are crimped on or soldered on. I solder these on, heat the end with a torch, melt solder in end, fill half way full, then insert wire into molten solder. Wear gloves and hold end with a vise grip. I also use large heat shrink tubing to seal connection. Install the felt washers on the post and spray the terminal with the thick red protective coating, this will outlast the cheap factory connections.
    Dave
  2. #12
    Gold Member MrChris's Avatar
    Join Date
    Dec 2006
    Posts
    341
    Georgia
    Mahindra 3215HST
    Default
    I had a similar issue with the negative side and I was able to just replace the whole short cable with a new one. Since your dealing with the positive side I think your only option is to replace the end.
    Attached Thumbnails Attached Thumbnails Mahindra Battery Terminal Corrosion-image-116887620.jpg
    '06 Mahindra 3215HST,KMW ML111 FEL,BushHog SBX65 Boxblade,BushHog RZ160 Rotary Cutter,Kasco KOS604 Seeder,Cosmo 250 3PT Spreader,Southern 6' Landscape Rake,Rhino LR 6' Rear Blade
  3. #13
    Gold Member kneedeep's Avatar
    Join Date
    Apr 2012
    Posts
    387
    Deep in the Heart of Dixie- Central Alabama and the Mississippi Delta
    2003 Mahindra 3510
    Do you guys use battery maintaners?
    My original untreated Mahindra battery lasted 9 years and corrosion was never a problem. I don't know if the maintainer had anything to do with it or not??
    PROUD AIR FORCE DAD
  4. #14
    Veteran Member AchingBack's Avatar
    Join Date
    Jun 2005
    Posts
    1,615
    Southern Oregon
    Mahindra 2615HST
    I use the cheap Harbor Freight float chargers on my tractor, and electric start field and brush mower. Both batteries seem as strong as they did 3-4 years ago.
    I thank God for these gifts: 2005 Mahindra 2615 HST w/loader, (485 hours), and 3710 backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, Paumco Quick Spade, Agri-Ease 3 point log splitter.
  5. #15
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Quote Originally Posted by BillyCrash View Post
    My 3016 wouldn't start this weekend. Checked the battery and the terminal bracket was corroded away. The problem is the bracket is a think piece of metal instead of solid metal like car brackets. Dissapointing construction.
    Sorry, but that's nothing more than a lack of maintenance.
    ::Sent from a standard desktop keyboard::
    My Photobucket
  6. #16
    Join Date
    Jun 2005
    Posts
    1,615
    Southern Oregon
    Mahindra 2615HST
    Quote Originally Posted by Willl View Post
    Frequent checks of the battery is just as important as other tractor maintenance. Because mine is under the air filter container, it is hard to get a good look at it without a strong flash light. Those battery caps can vibrate loose, especially if they weren't firmly tapped down with a light instrument. I suggest looking at the battery, and cables, no less than once a month.
  7. #17
    Join Date
    Dec 2006
    Posts
    341
    Georgia
    Mahindra 3215HST
    Default
    First tractor for me. Thought it would be similar to autos but Achingback is right. You need to check these cables more frequently. But I know the new cable I installed has a more traditional end which I don't think will ever corrode like the cheaper style they are using on everything now, even autos.
  8. #18
    Member
    Join Date
    Jun 2012
    Posts
    47
    Pendleton, mo
    Mahindra 4530
    I used a generic connector on my 2615, worked fine.
  9. #19
    Join Date
    Apr 2005
    Posts
    702
    Erin, Tenn.
    2001 Mahindra 4110
    My Nissan truck is almost 20 years old and has almost 260K miles on it and those exact same type battery terminals look like they did when I bought it new, just takes proper maintenance. My 4110 terminals are now 11 years old and on the 3rd battery and they are still in great condition too. The acidic gasses leak up around the posts on all batteries, some worse than others, that's why I use the little felts under the terminals on every battery of mine that I additionally soak in the spray protector and then spray the the whole post/terminal once it's complete. Been a pro mechanic for over 40 years now and this has ALWAYS worked for me. Grease is NOT good for this, it will eventually get between the terminal & post and cause connection problems. The spray stuff doesn't melt and get down between the terminal & post and will not give this problem. Have dealt with this on literally thousands of autos over the years. Permatex and CRC both make good spray protectants and a can will last for years ...
    2001 Mahindra 4110, FEL w/5' & 6' QA buckets & forks for the 5', 6' Atlas boxblade, older 6' Howse rotary, Leinbach 7300 PHD w/9" & 12", MF 2/3 bottom plow, 20"x6' bog disc, KK subsoiler, KK middlebuster, Kubota BL60C 5' tiller, Maschio 6' finish mower.
  10. #20
    Veteran Member buck12's Avatar
    Join Date
    May 2006
    Posts
    1,215
    NW Mississippi
    Mahindra 2615
    Default
    Quote Originally Posted by Srb08
    I did the same on my 2615 last year. I am on the original battery on a 2006 model.
Similar Threads
  1. battery corrosion/good battery dead now
    By mitchelli in forum Craftsman / Sears
    Last Post: 05-02-2010, 04:10 PM
  2. Battery Terminal Corrosion Prevention
    By weldingisfun in forum Trailers & Transportation
    Last Post: 01-20-2010, 01:19 AM
  3. Battery terminal problem
    By RobT in forum Owning/Operating
    Last Post: 09-25-2007, 02:59 PM
  4. battery terminal corrosion
    By kpk in forum New Holland Owning/Operating
    Last Post: 05-13-2004, 07:32 PM
  5. Battery terminal corrosion on 4400
    By Mike_S in forum John Deere Owning/Operating
    Last Post: 06-29-2003, 11:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
