Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
  1. #31
    Silver Member ToolBoxTavern's Avatar
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    Default Re: Transfer Tank
    Quote Originally Posted by sdkubota View Post
    I would have purchased a normal pickup tank. I used to carry a 110 gal "L" tank with a toolbox on top. Great combo and you don't have to run to the pumps all the time to get re-filled.
    Thought bout buying one, but all the cheap ones are steel. At tractor supply a 50gal was $250. They did have 100gal on sale for $300, but I might not use all of it for 3+/- months. I dont want fuel sitting that long. Not to mention you still have to buy a pump and the cheapest is the one new is what I got for $125. I dont like the way the tanks are set up with the drain plugs either. The tool box combo is nice and looks great, but I like to be able to use the full 8' bed on my pick up.
  2. #32
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    Quote Originally Posted by CBW1999 View Post
    Home Depot, Lowes both have a variety. Gotta read the labels real close to make sure it fits the application. I prefer to go to Ace Hardware- their "house brand" is usually less expensive.
    All have to see how close there is an Ace Hardware to me.
  3. #33
    Bronze Member hbarski's Avatar
    Join Date
    Apr 2005
    Posts
    67
    Tenn/Arkansas
    3930 Ford/Newholland Mitsubishi MT2001D CASE 580 CK
    Mineral oil base.
    Light travels faster than sound, that is why some people appear brighter before they speak......
  4. #34
    Super Star Member
    Join Date
    Jul 2011
    Posts
    10,502
    Yanceyville, North Carolina
    Kubota L4400
    By reviewing all the posts, it is evident that many members have a well thought out system. This is the system that I incorporated. My kubota L4400 has a 11.1 gallon tank. I bought a Duramax flo-n-go at TSC. It holds 14 gallon and I sprayed it yellow and put a "Diesel" sign on it because it was originally red in color. I built a set of steps with side rails a foot taller than the hood of my tractor. With my son-in-law's assistance, I place the tank on top of the steps and use the hose to fill the tank. It is fairly easy to fill the tank at the fuel pump and is portable with the use of the wheels. It stores away in the corner of the shed easy. Flo N' Go - Products
    The PUPIL who does not surpass his Master, fails his Master.
  5. #35
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    Quote Originally Posted by hbarski View Post
    Mineral oil base.
    Thanx again!
  6. #36
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    I took a piece of flat and wrapped around a piece of pipe bout the size of the tank to make the straps.
  7. #37
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    Some more pics of the skid for the tank.
    Transfer Tank-2012-09-23-16.23.25.jpgTransfer Tank-2012-09-23-17.28.38.jpgTransfer Tank-2012-09-23-19.12.48.jpgTransfer Tank-2012-09-23-19.12.58.jpgTransfer Tank-2012-09-23-19.35.50.jpgTransfer Tank-2012-09-23-19.36.06.jpg
  8. #38
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    Update. Got a bit more done.
    1st pic - trying to figure out pump placement.
    2nd pic -you can see lifting points, nozzle holder, shelves, straps with part of turn buckles welded on, chains to hook to other end of turn buckles, brace for holding pipe with fuel filter mounting base, and some bad welds.
    3rd pic - we got it grinded, wire wheeled, and primed right before storm came in.
    We still need to finish painting and clean aluminum fuel tank before mounting. Also need to make sure we put something between aluminum tank and metal straps or the steel will rot out the aluminum if my memory serves me correct.
    Transfer Tank-2012-10-22-12.52.45.jpgTransfer Tank-2012-10-23-17.13.37.jpgTransfer Tank-2012-10-25-16.44.02.jpg
  9. #39
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,482
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    You have me looking for an aluminum truck tank. Nice work.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  10. #40
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    Quote Originally Posted by dex3361 View Post
    It is really the way to go. If you have a big truck salvage near you then you can end up with a tank that will not rust and have a larger or same fuel capacity for less money.
Similar Threads
  1. Fuel transfer tank
    By CircleJFarm in forum Oil, Fuel & Lubricants
    Last Post: 02-03-2008, 02:44 AM
  2. New Fuel Transfer Tank ?
    By PSDStu in forum Oil, Fuel & Lubricants
    Last Post: 02-06-2007, 02:48 PM
  3. gasoline transfer tank?
    By bdog in forum Owning/Operating
    Last Post: 11-06-2005, 12:44 AM
  4. Fuel Transfer Tank
    By DUMBDOG in forum Oil, Fuel & Lubricants
    Last Post: 05-27-2005, 02:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
