Results 1 to 6 of 6
  1. #1
    Gold Member MrChris's Avatar
    Join Date
    Dec 2006
    Posts
    341
    Georgia
    Mahindra 3215HST
    Default
    It's time to hook up some extra lighting to my canopy. I know there is a rear electrical connection for a rear light. It gets power from the headlight switch. Wondering if this cicuit can handle 2 additional 55 watt halogen lights. At the fuse holder in the engine compartment there is a 10 amp fuse dedicated to the headights. Some questions? Why does the rear connector have four wires? The last fuse location on the bottom says it is for the PTO switch, work light and horn. I don't have any of these on my tractor. Wondering where the wiring for any of these extras might be to tap into?
    Attached Thumbnails Attached Thumbnails -image-2676241831-jpg   -image-2510775872-jpg
    '06 Mahindra 3215HST,KMW ML111 FEL,BushHog SBX65 Boxblade,BushHog RZ160 Rotary Cutter,Kasco KOS604 Seeder,Cosmo 250 3PT Spreader,Southern 6' Landscape Rake,Rhino LR 6' Rear Blade
  2. #2
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    Default Re: 3215 rear light connection
    voltage x amperage = watts
    12 vdc x 10 amp = 120 watts
    2 x 55 watt lights pull 110 watts
    you should be fine
    one wire is your 12vdc posative
    the other will be ground
    usefull for when mounting lights to a composite canopy ... which has no ground.
    you will run two wires to the lights
    my canopy has a very good ground and i only ran a posative wire to each light and grounded the lights to the canopy thru the light housing mounts to complete the 12 volt circuit.
    use a test light or meter to find out which one is negative
    if you mix them up you will blow the fuse
    a multimeter set to dc voltage will read negative 12 vdc when the leads are reversed on your light leads.
    a continuity meter can be used to check the ground source and will give you an idea if the wire harness ground is good.
    a light bulb with two loose wire leads connected to the light, one grounded to the tractor and then the other lead to test each terminal for the hot or posative connector will also work.
    tom
  3. #3
    Platinum Member kneedeep's Avatar
    Join Date
    Apr 2012
    Posts
    779
    Central AL & MS Delta
    Mahindra 3510 and Mahindra 5500 4WD
    Maybe if the light was there it would connect to the 4 prong, my old 3510 has all of those. The work light comes on with the headlights and has a on/off button on the light,
    PROUD AIR FORCE DAD
  4. #4
    Join Date
    Dec 2006
    Posts
    341
    Georgia
    Mahindra 3215HST
    Default
    Hoping someone who has a 3215/3316 gear could tell me what the color codes are for the wires that go to their PTO switch. Thanks.
  5. #5
    Join Date
    Dec 2006
    Posts
    341
    Georgia
    Mahindra 3215HST
    Default
    Took some time to trace wires today. First the rear plug has four wires in it. Of course black wire is ground. Blue/red wire is 12 volt from light switch. Green/black is left turn signal and Green/white is right turn signal. Then traced Yellow/red wire from 10 amp fuse marked horn/pto/work light up to an unused pin in the light switch wiring harness. I think I will use this wire as my 12 volt power for the added lights.
  6. #6
    Join Date
    Dec 2006
    Posts
    341
    Georgia
    Mahindra 3215HST
    Default
    Finished part 1. Decided to add a 35 watt halogen work light with built in switch on the rear fender like you typically see. Drilled hole,installed grommet and ran 12 volt wire connection down to existing plug. Light is grounded through bolt of bracket. Pretty simple. Total wattage including new work light totals 108 watts on 10 amp fuse so I should be fine. Now I have to decide if I want to add 1 or 2 lights on the canopy facing forward. This will be a little more complicated as I will have to add a switch on the dash, tie into that auxillary unused 10 amp fused wire and run wires up the rops and around the canopy to the lights. And least now if I'm running out of daylight while I'm working the tractor I'll have light on my implements.
    Attached Thumbnails Attached Thumbnails -image-3351516685-jpg
Similar Threads
  1. Kubota B7800 work light connection
    By wihiker in forum Parts/Repairs
    Last Post: 03-31-2008, 05:01 PM
  2. trailer light connection for 5500 fwd
    By tractorboy5500 in forum Mahindra Owning/Operating
    Last Post: 12-12-2006, 01:11 AM
  3. Light connection help!!!
    By g42guy in forum Customization
    Last Post: 12-19-2004, 04:25 PM
  4. Trailer light connection for TC40D
    By TCowner in forum New Holland Owning/Operating
    Last Post: 11-01-2003, 10:31 AM
  5. Trailer light connection for TC40D
    By TCowner in forum Trailers & Transportation
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
