Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Sep 2010
    Posts
    25
    Default 8560 quick attach loader question.
    I may have messed up my loader not sure. I was bush hogging and knew I needed to move a mineral feeder so I attached the forks on the loader. I wasn't lined up exactly with the forks so I couldn't get one of the sides to latch. I figured no big deal just moving the mineral feeder that may weigh 100 lbs. Moved it no big deal. Went own bush hogging and a few hours later came up on a big rock that I had been meaning to move. Didn't think about one side not being locked in. Moved the rock and when I wad setting it down is when the one side that wasn't latched came off. Got the forks out from under the rock and was going to unlatch the forks and rehook them back up. That's when I noticed that on side was out more than the other. I looked to see if anything was bent but didn't see anything. The cylinders that control the tilt on the bucket. One of them is out about 2 inches more than the other. They move together so it stays the same all the way down or all the way up. I was wandering if there was an easy fix or if its going to cost me.
    Any advice would be greatly appreciated.
  2. #2
    Elite Member AchingBack's Avatar
    Join Date
    Jun 2005
    Posts
    3,512
    Southern Oregon
    Mahindra 2615HST
    Default Re: 8560 quick attach loader question.
    Check to see if one of the cylinder rods is bowed. If so, you have your answer.
    I thank God for these gifts: 2005 Mahindra 2615 HST w/loader, (875 hours), and 3710 backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, Paumco Quick Spade, Agri-Ease 3 point log splitter. Pine straw rake.
  3. #3
    Member
    Join Date
    Sep 2010
    Posts
    25
    Default
    Both are straight and work fine.
  4. #4
    Join Date
    Sep 2005
    Posts
    1,746
    Batavia, NY
    Mahindra -------------
    I think you bent or twisted the quick attach plate on the tractor
    Galen LaWall
    Your Mahindra Tractor Dealer
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  5. #5
    Member
    Join Date
    Sep 2010
    Posts
    25
    Default
    Quote Originally Posted by LAWALLSTRACTOR
    You were correct. Thanks
  6. #6
    Member Richard R.'s Avatar
    Join Date
    Mar 2007
    Posts
    48
    Molino FL
    2000 ford/ bushhog loader, 3203 john deere, 5035 mahindra ML130 FEL
    please see my post of today on the pallet forks on my ml 130
    Richard
    be leary of some one that says they are a expert. if they tell you they are knowledgeable then trust them.
    remember an EX is a Has been and a SPERT is a drip under pressure!!!
Similar Threads
  1. Quick Attach Loader/Bucket Question
    By Amos22 in forum Kubota Buying/Pricing
    Last Post: 08-15-2012, 12:36 PM
  2. Quick attach loader question
    By raw23062 in forum New Holland Owning/Operating
    Last Post: 02-26-2012, 06:27 PM
  3. Not so quick attach loader
    By zmansmac in forum Hydraulics
    Last Post: 06-01-2011, 11:22 PM
  4. Quick attach loader-who does it??
    By KB9UDE in forum John Deere Owning/Operating
    Last Post: 07-24-2008, 02:38 PM
  5. JD 300X/C loader quick attach loader arm brackets
    By BloomingtonMike in forum John Deere Owning/Operating
    Last Post: 03-22-2006, 08:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
