Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Aug 2012
    Posts
    13
    lone star, texas
    c4005-di
    Default C4005 differential lock problem
    Mornin folks,
    I recently bought this tractor for my 31 acre place. I decided after reading the operators and service manuals that I didn't need the differential lock engaged(it was engaged when I took delivery of it). The spring loaded pedal is all the way down with the shaft preventing it from being released and going back up.-pic836-jpg-pic837-jpg The mahindra manuals don't say anything about how to disengage the differential or how to go about it.I've wd-40'd it ,foot pedaled the heck out of it, and vigorously cussed it with no results for my labors.
    I figure the tractor probably has been this way since it was newbecause the brake pedals were ganged together and it took a lot of wd-40 and prying to ungang em.If this makes any sense , any help would be appreciated.
  2. #2
    Join Date
    Jul 2003
    Posts
    1,750
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    Default Re: C4005 differential lock problem
    Hopefully the previous owner didn't make any sharp turns on hard surfaces with the diff lock on...can cause bad things...DON'T turn sharp with this until you get it to release...once you do, make sure that you still have drive in both sides...BobG in VA
  3. #3
    New Member
    Join Date
    Aug 2012
    Posts
    13
    lone star, texas
    c4005-di
    thanks for the comment but I need a proceedure spelled out on How to disengage the differential lock. Do you push down on the pedal to unlock it or do you reach down and pull up on the pedal while backing up or do you say abbra cadabbra while hoping it will pop up? There is no proceedure on the steps to take and what to look for as you disengage the durned thing.
  4. #4
    Join Date
    Sep 2005
    Posts
    1,740
    Batavia, NY
    Mahindra -------------
    When working properly it should disenguage (Pop up) on its own.
    Galen LaWall
    Your Mahindra Tractor Dealer
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
Similar Threads
  1. Bizzare differential lock problem...
    By linrick1 in forum Parts/Repairs
    Last Post: 01-12-2009, 06:06 PM
  2. Differential lock up
    By schwant in forum Cub Cadet Tractors
    Last Post: 01-07-2009, 11:42 AM
  3. TN 55, differential lock problem,
    By maplehillfrm in forum New Holland Owning/Operating
    Last Post: 02-13-2008, 10:42 AM
  4. Is there a problem with my differential lock?
    By Snatchface in forum Kubota Owning/Operating
    Last Post: 06-23-2007, 03:11 PM
  5. TC24DA Differential Lock Won't Lock.
    By JSUnlimited in forum New Holland Owning/Operating
    Last Post: 07-23-2006, 11:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
