Results 1 to 4 of 4
12-12-2012, 01:44 PM #1New Member
- Join Date
- Jun 2010
- Posts
- 5
4500 battery
I need to replace the battery on my 2006 4500.
looks like if I remove the air cleaner canister and hose, maybe I can just reach in and pull the old one straight up and out. or is there an easier way ? remove front grill or... ? just thought I would ask before I skin my knuckles.
any recommendations on what size/ type to replace it with ?
thanks
12-14-2012, 09:19 AM #2Member
- Join Date
- Nov 2008
- Posts
- 33
- Location
- Northwest Alabama
- Tractor
- IH 354
Re: 4500 battery
txcowrancher,
We use the Interstate 31P-MHD battery. It is a perfect fit and has plenty of cranking amps.
There really is no easy to do this job. The grille being out really gives better access.
12-15-2012, 04:47 AM #3Member
- Join Date
- Mar 2012
- Posts
- 42
- Location
- Dardanelle, AR
- Tractor
- Many Mahindras
Re: 4500 battery
The best way to get the battery out is taking the 5 small bolts out of the red sheet metal under the grill and removing the horn or bent it up a little. Then you can roll the battery out the front.
12-15-2012, 07:24 AM #4Veteran Member
- Join Date
- Dec 2006
- Posts
- 1,453
- Location
- West Bell County, Texas
- Tractor
- Mahindra 4500 4WD w/FEL, and Scotts S2048 lawn tractor
Re: 4500 battery
Remove the grill. It is really not that difficult. Going out the top is nearly impossible.
Similar Threads
JD 4500
By SHANE1 in forum John Deere Buying/PricingReplies: 5Last Post: 09-30-2010, 03:42 PM -
4500
By mikedeere in forum John Deere Owning/OperatingReplies: 7Last Post: 05-30-2010, 12:40 PM -
battery corrosion/good battery dead now
By mitchelli in forum Craftsman / SearsReplies: 3Last Post: 05-02-2010, 04:10 PM -
JD 4500
By mikedeere in forum John Deere Owning/OperatingReplies: 4Last Post: 08-21-2007, 09:31 AM -
Battery Tender vs Battery Minder
By MikePA in forum Rural LivingReplies: 4Last Post: 06-10-2005, 02:48 PM
