Ram4x4
Ok, so I've had a chance to work with the new 5035 HST and I am wondering...
When I press down on the pedal to get moving there is 4-5 second delay before it starts moving. Is this normal? Especially noticeable when using the FEL and I scoop, back up, then switch to the forward pedal to get moving there is that long delay. It starts slow and after a few more seconds you can kind of feel it "grab" as it starts to move. If this normal then OK, but after a lot of backing up, going forward it's kind of annoying as I'm sitting there with a "ok, let's go" feeling after hitting the pedals to get moving. I'm running her at around 2000 RPM when using the FEL which seems a decent RPM to work at. Mowing I run her up to the 540 mark on the tach which around 2200 RPM.
Also, the brakes seem useless. After rolling, letting off the pedal and hit the brakes there seems to be no braking effect and the tranny starts whining hard like the brakes are fighting it. It's like letting off the pedal doesn't want to "disengage" the HST. Especially bad when going down a slight grade as the brakes will not stop the tractor at all. Might as well not have any brakes at all.
I hope this isn't normal and it's just a matter of some kind of adjustment or something.
