Results 11 to 20 of 34
01-23-2013, 03:56 PM #11We are on our way to being farmers! Our site is always under construction so check back often for updates.
http://www.philosophyfarmstyle.com/
01-23-2013, 03:57 PM #12
Re: 50 hr service question
Does anyone have any pics of the tranny screen/strainer procedure?
01-23-2013, 04:04 PM #13
I plan on cleaning the screen at 50hrs. Always a good time to remove metal shavings from any system. Not sure I would reuse the drained oil unless it was perfectly clean. IMO the peace of mind from new oil outweighs the few dollars saved.
01-23-2013, 05:10 PM #14
01-24-2013, 12:25 AM #15
I've always found everything flows downhill - usually right where I'm standing.
Sorry, couldn't help myself.
01-24-2013, 12:40 AM #16
Also, I don't really know if this works but it does make sense. Have someone hold the hose of a shopvac, on of course, over the dipstick hole, remove the dipstick first, while you remove and clean the screen. Have read where nothing leaks out at all.
If you try this let me know if it really works.
01-24-2013, 07:42 AM #17Bronze Member
- Join Date
- Jun 2010
- Posts
- 57
- Location
- Grimes county Texas
- Tractor
- Mahindra 4025
I just changed all the transmission fluid and filter on my 4025 at the 50 hour mark, by the time I went to all the trouble trying to save it, just didnt make sense. I still would have had to buy the fluid to top it off. I used tractor supply "Premium" transmission and hydraulic fluid (approved for Mahindra as per the label) and mahindra filter in mine with no performance problems. Make sure to run the loader and 3 point all the way up and down a few times each to purgae the air. I left the engine oil change till the 100 hour mark. Good luck and have fun.
01-24-2013, 07:58 AM #18We are on our way to being farmers! Our site is always under construction so check back often for updates.
01-24-2013, 07:58 AM #19We are on our way to being farmers! Our site is always under construction so check back often for updates.
01-24-2013, 07:59 AM #20
Similar Threads
SERVICE BY DEALER FOR 50 SERVICE
By Cropdustr in forum Massey Ferguson Buying/PricingReplies: 9Last Post: 02-25-2012, 05:27 PM -
BX24 50 hr. service tomorrow. Any input? Service bulletins?
By NoviceguyInCT in forum Kubota Owning/OperatingReplies: 0Last Post: 08-07-2006, 04:13 PM -
50 hr Service
By cokeman in forum Kubota Owning/OperatingReplies: 10Last Post: 08-30-2004, 07:43 PM -
L3830/just did my 50 hr service-service light??
By BWS in forum Kubota Owning/OperatingReplies: 2Last Post: 05-11-2004, 10:10 PM
