Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Feb 2010
    Posts
    15
    Far northern CA
    Mahindra 2615
    Default 2615 No juice!
    Scratching my head on this one; maybe you can help. Had taken my old battery out for charging. Held the charge for a couple of days, so reinstalled it. The minute I started the crank, everything went dead. Re-checked the battery and found that my Neg cable wasn't tight. Tightened--no juice, nothing, no lights, nothing. Checked all the fuses, all okay. Battery still holding at 12.4 volts. Is installed with pos and neg cables correct. What's up?
  2. #2
    Gold Member
    Join Date
    Apr 2011
    Posts
    381
    Massachusetts
    Mahindra 2216
    Default Re: 2615 No juice!
    If you haven't done so already, check the other ends of the battery cables where they are terminated. I seem to recall corrosion or connection problems people have had to the cable that I think connects to the tractor frame. Presume you cleaned the battery terminals and posts when you had the battery out.
  3. #3
    New Member
    Join Date
    Feb 2010
    Posts
    15
    Far northern CA
    Mahindra 2615
    Yes, I cleaned them. Other ends of cables are fine.
  4. #4
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,680
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST
    You have to measure the voltages whilst you try to crank her. That way, you will find if you have a battery that is opening up under load, clamp, cable, starter, etc.... Good luck, Jerry .....
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  5. #5
    New Member
    Join Date
    Feb 2010
    Posts
    15
    Far northern CA
    Mahindra 2615
    Thanks, Jerry; however, there's no juice at the switch; no lights, nothing. This is an old battery; however, it is holding a charge at 12.5. Should be enough for lights and switch.
  6. #6
    Join Date
    Feb 2004
    Posts
    2,680
    Use your meter and check any wires coming off the battery. You may have blown a fuseable link... which is a fuse that is in the wire, kind of a failsafe, if you have voltage on one end of the wire.. and not on the other... then either the connector on the wire [ battery clamp, etc. ] is bad, or you have blown that fuseable link.... They are sometimes not easy to find, just a bulge in the wire... sometimes covered with shrink wrap.. Good luck, Jerry...
  7. #7
    New Member
    Join Date
    Feb 2010
    Posts
    15
    Far northern CA
    Mahindra 2615
    Okay, thanks, Jerry. Will check it out.
  8. #8
    Join Date
    Sep 2005
    Posts
    1,746
    Batavia, NY
    Mahindra -------------
    Use your meter and put the positive lead to the lug on the solonoid where the positive cable attaches and the negative lead to a bare spot on the tractor engine or frame. If your battery connections are good you should have the same reading that you get on the battery. I would check this before you get any further. If that checks out good then put the tractor in neutral and then try to jump the starter solonoid. If that starts the tractor, I would start checking the wiring. I believe there is a second small wire on the positive terminal of the battery. Check for opens in that line.
    Galen LaWall
    Your Mahindra Tractor Dealer
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  9. #9
    New Member
    Join Date
    Feb 2010
    Posts
    15
    Far northern CA
    Mahindra 2615
    Thanks, Galen, will check it out.
  10. #10
    Gold Member
    Join Date
    Apr 2011
    Posts
    381
    Massachusetts
    Mahindra 2216
    Any luck with this Steve?
Similar Threads
  1. VERY expensive beet juice!
    By canoetrpr in forum Owning/Operating
    Last Post: 10-20-2017, 08:11 AM
  2. Beat Juice -- does it freeze?
    By emcvay in forum Owning/Operating
    Last Post: 07-05-2012, 12:19 AM
  3. Beet Juice Bath
    By AMR in forum Kubota Owning/Operating
    Last Post: 03-12-2012, 09:59 AM
  4. BX2200 NO JUICE!
    By g42guy in forum Kubota Owning/Operating
    Last Post: 05-15-2009, 03:48 PM
  5. Replies: 8
    Last Post: 03-10-2004, 08:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
