Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Member
    Join Date
    Sep 2010
    Posts
    25
    Default 8560 audible alarm goes off after 5 minutes.
    I Have a 8560 with 165 hours on it. After I crank it and it runs for about 5 minutes an alarm goes off. There are no other service lights on. I checked the hydraulic fluid level and it was a little low. Added fluid and still get the alarm. Any suggestions. Do you have to reset alarm like at the 50 hour oil change. Thanks
  2. #2
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,253
    Red Bluff, CA
    Changes often!
    Default Re: 8560 audible alarm goes off after 5 minutes.
    There are several sensors that report to the dash and if a sensor does not give the expected result it sets off a warning at 5 minutes almost exactly. I don't think the service alarm goes off right at 5 minutes, so that probably isn't the issue. I'd check with your dealer and see if he can figure out what is triggering the alarm. It might just be important, so I don't recommend ignoring it for long.
    Dave
    Dave's Tractor, Inc.
    Red Bluff, California
  3. #3
    Member
    Join Date
    Sep 2010
    Posts
    25
    Default
    My dealer is out of business. Who should I contact.
  4. #4
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,253
    Red Bluff, CA
    Changes often!
    Where are you located?
    Dave
  5. #5
    Member
    Join Date
    Sep 2010
    Posts
    25
    Default
    Lafayette, tn
  6. #6
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,253
    Red Bluff, CA
    Changes often!
    I'll get back to you with a suggestion. I'm checking to see who is close to you.
    Dave
  7. #7
    Member
    Join Date
    Sep 2010
    Posts
    25
    Default
    Thanks
  8. #8
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,253
    Red Bluff, CA
    Changes often!
    I'd suggest two different places: Valley Farm in Science Hill, KY. I've known Wes and Shelia for years. Good folks, and experienced with the larger Mahindra models. If that is not handy or they are too busy, go to Greene's Trailer in Sneedville, TN. I've met these folks personally as well and have heard good things about them. You would be in good hands with either dealership.
    I did not map this out, so I don't know how handy either of these dealers are to your location. Nor do I want to suggest that other local dealers are not adequate to take care of you. It is just that I know these folks, and we tend to suggest people we know.
    Dave
  9. #9
    Member
    Join Date
    Sep 2010
    Posts
    25
    Default
    Spoke with a dealer close by. They had not heard of this problem. They called the area service rep. He told me how to check the scavenger pump switch. It was bad. Replaced it every thing is back to normal with no alarms. Thanks again for the help.
  10. #10
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,253
    Red Bluff, CA
    Changes often!
    Quote Originally Posted by sirchancelor View Post
    Excellent! It isn't a common issue, but it is an odd thing for a beeper to go off at exactly 5 minutes....and that is the key to identifying it as a pressure or pressure signal issue. Glad you are good to go.
    Dave
Similar Threads
  1. 8560
    By no time in forum Mahindra Buying/Pricing
    Last Post: 05-09-2009, 10:50 AM
  2. Audible alarm for parking brake???
    By Chuck K. in forum Owning/Operating
    Last Post: 06-15-2008, 04:38 PM
  3. 8560
    By jwcinpk in forum Mahindra Owning/Operating
    Last Post: 02-13-2008, 01:22 AM
  4. audible master caution/warning alarm
    By Cidertom in forum John Deere Owning/Operating
    Last Post: 12-06-2006, 08:46 PM
  5. Need help on a audible parking brake alarm M105X
    By Mseriesfreak in forum Kubota Owning/Operating
    Last Post: 11-05-2005, 08:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
