Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Apr 2013
    Posts
    10
    Broken Bow OK
    mahindra 4530
    Default 4530 Mahindra wont shut down/dash lights stay on
    Please Help! Just got my 08 Mahindra 4530. Its been working fine but today when I went to turn in off it would not stop running. I finally found a fuse to pull and got it to shut down. The dash light also wont go off. I took the dash off and pulled the the key switch plug apart and they still stay lite up. I tried the starter again with the key switch and the tractor started but still would not shut down with the switch. Could my problem be with the switch. The wiring diagram shows a shut down solenoid but I am not sure where it is. Any advise?
  2. #2
    Join Date
    Sep 2005
    Posts
    1,746
    Batavia, NY
    Mahindra -------------
    Default Re: 4530 Mahindra wont shut down/dash lights stay on
    The shut down solonoid is located on the fuel injection pump. There is obviously a short somewhere that is feeding power to the shut down solonoid and the dash.
    Galen LaWall
    Your Mahindra Tractor Dealer
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  3. #3
    New Member
    Join Date
    Apr 2013
    Posts
    10
    Broken Bow OK
    mahindra 4530
    Thanks Galen. I will look for it. I also tested the wires going to the key switch. There are three wires. Two are staying hot. I can jump between either of the hots to the dead one which is much smaller in size and it will start the tractor. That dosnt seem right to me.
  4. #4
    Silver Member seaneastok's Avatar
    Join Date
    Sep 2012
    Posts
    205
    Panama,Ok
    2012 Mahindra 4530 4x4 ML245 FEL. 58 Ford 861D.65 Ford 4000
    Welcome from Panama Ok neighbor..lol..Sounds like possibly the switch isnt breaking power to the solenoid..and if the two circuits are tied together (lighting and shutdown solenoid) would cause what you are describing..I dont have my manual in front of me right now but there should only be one hot lead(12 volt)with the key switch in the off position...Keep us posted.
    Sean
  5. #5
    Join Date
    Sep 2005
    Posts
    1,746
    Batavia, NY
    Sean is right. If there are only 3 wires going to the ignition switch, then only one should be hot when the switch is in the off position. If you unplugged the switch when you were jumping the wires, then the problem isn't in the switch, and the main wire that is supposed to supply power, from the switch to most of the tractors electrical components, is shorting to a power source someplace other than the switch. If you didn't unplug the switch when you jumped the wires, it could well be in the switch, and that would be your easiest repair senario. Good luck with it.
    Galen LaWall
    185 Pearl Street
    585.343.0770
  6. #6
    Join Date
    Feb 2011
    Posts
    867
    Parish NY
    555DTC Farmall 200
    Remove the switch and test it for continuity. If it is open when off it is good and start tracing wires. If you do not have a volt meter time to get one. Even a cheap $5 HF one would get the job done for you.
  7. #7
    New Member
    Join Date
    Apr 2013
    Posts
    10
    Broken Bow OK
    mahindra 4530
    Thank guys. I have a meter and I will start checking. I did find a wiring pdf for the tractor. Maybe this will help someone else also.
    Attached Files Attached Files
  8. #8
    New Member
    Join Date
    Apr 2013
    Posts
    10
    Broken Bow OK
    mahindra 4530
    Okay. I got it fixed. I ohmed out the switch Clint and checked it out okay. After undoing a lot of the wiring harness I finally found a small wire that went to an auxillary hook up on the back of the tractor. The end of it was pretty beat up and exposed. It was that way when I got it so I didnt start looking there first off. I had assumed it was the key switch. When I opened up the wiring cover it was melted for a long way down the harness. You were right Galen! I removed the wire and checked the others for damage. I ended up cutting the wire out and removed the entire section of auxillary harness and taped up the wire ends after making sure there was no more bad wires. Thanks for the help guys,
  9. #9
    Join Date
    Feb 2011
    Posts
    867
    Parish NY
    555DTC Farmall 200
    Sweet glad it was an easy and cheap fi.
  10. #10
    Join Date
    Sep 2005
    Posts
    1,746
    Batavia, NY
    Glad to hear it is fixed.
    Galen LaWall
    185 Pearl Street
    585.343.0770
Similar Threads
  1. ZD 21 Wont shut off
    By wopicetti in forum Kubota Lawn & Garden
    Last Post: 08-03-2012, 03:09 PM
  2. 3-Point Hitch wont stay up
    By Licking in forum Chinese Tractors
    Last Post: 05-08-2012, 06:32 AM
  3. BX24 wont start and wont shut off
    By Johndeere3720 in forum Kubota Owning/Operating
    Last Post: 03-25-2010, 07:16 PM
  4. BX 23 wont shut off
    By DannyD in forum Kubota Owning/Operating
    Last Post: 01-03-2008, 08:31 PM
  5. B Series Dash Lights: Mystery Lights
    By DAP in forum Kubota Owning/Operating
    Last Post: 01-30-2007, 01:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
