Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    5
    ****,wa
    mahindra
    Default 3710 Backhoe issues......HELP
    working all morning. then it felt like it lost pressure when lifting bucket out of hole. it wouldn't lift so I checked for blown lines or any leaks and have found none. fluid is full. if I stay on the controls it will take 5-10 seconds of super slow movement then it kicks on and works normally. until I release controls then have to start all over again and wait 5-10 seconds for it to move or lift.
    I am thinking it could be the pressure relief valve.... but I cannot find it and have searched the location on this forum to no success.
    any help would be greatly appreciated.
  2. #2
    New Member
    Join Date
    May 2013
    Posts
    5
    ****,wa
    mahindra
    Default Re: 3710 Backhoe issues......HELP
    forgot to mention FEL and everything else works fine.
  3. #3
    Veteran Member rback33's Avatar
    Join Date
    May 2003
    Posts
    1,531
    Kansas
    Check your manual for where the main relief is. Pull that relief and look under it. There should be an inlet spool and spring in there. I bet the spring is broken. If it is, you can get a kit. 0580-6295 is the part number.
  4. #4
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,278
    Red Bluff, CA
    Changes often!
    Quote Originally Posted by rback33 View Post
    Agree. We had a few of those break out of the dozens of 3710s we sold. The good news is the replacement springs seem to last forever. Jeremy, thanks for listing the part number, that will make life easier for the customer.
    Dave
    Dave's Tractor, Inc.
    Red Bluff, California
  5. #5
    Join Date
    May 2003
    Posts
    1,531
    Kansas
    Quote Originally Posted by DavesTractor View Post
    Hopefully it helped. I know that part is not actually listed in the manual so it would be tough to locate. One thing I should say is I don't check in here NEAR as much as I used to, so people that have questions can always PM me... I will get the email notification that way.
  6. #6
    New Member
    Join Date
    May 2013
    Posts
    5
    ****,wa
    mahindra
    Found the Relief. Sure enough the spring broken into 3 pieces. ordered part.
    Thanks so very much you guys saved the day!!!!!!!!!
  7. #7
    Join Date
    May 2003
    Posts
    1,531
    Kansas
    Glad we could help!
Similar Threads
  1. 3710 backhoe subfarme pins
    By jwcinpk in forum Mahindra Owning/Operating
    Last Post: 10-21-2011, 10:26 AM
  2. Kubota Backhoe issues
    By 6s135 in forum Hydraulics
    Last Post: 04-21-2008, 10:19 AM
  3. Backhoe hydraulic plumbing for kubota 3710 to woods bh80x backhoe
    By cummins666 in forum Attachments
    Last Post: 05-07-2007, 04:42 PM
  4. Backhoe Any 2615HST owners have the 3710 backhoe?
    By George2615 in forum Mahindra Owning/Operating
    Last Post: 12-22-2005, 05:02 PM
  5. 4560 Backhoe for Kubota 3710
    By rossibob in forum Kubota Buying/Pricing
    Last Post: 04-05-2005, 07:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
