Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    New Member
    Join Date
    Jul 2013
    Posts
    9
    Thaxton, MS
    JD 4105/5303
    Default Mahindra 4025 vs 5530
    I will start off by saying this my first post. I really have enjoyed reading all of the info on here. Good stuff!!! I have 40 acres that I own and have another 50 I look after for deer hunting. Of the 90 acres, only about 20-25 acres are in pasture/fields/foodplots. The remaining acres are in timber and beaver swamps. Ok so here is the question, I like the simplicity of the 4025. I am just afraid that 40 hp will not be efficient to run a 6' bhog and a 6' rototiller. I know the 5530 should be more machine and a bit more efficient. Also, is there that much difference in the 3 cylinder vs the 4 cylinder? Those folks who have these models please chime in. I know I am comparing apples and oranges in a way but there is a substantial price difference in the 2. Also hauling will not be an issue since the properties are fairly close to each other. I have driven a 4025 and like it. I know it is a tank. Can I expect the same from the 5530? I think it is a higher end tractor vs the 4025 but is there enough difference between the 2 tractors to justify $5000.
    Any and all comments are appreciated.
  2. #2
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,039
    Central Ohio
    Kubota MX5100
    Default Re: Mahindra 4025 vs 5530
    I dont own a mahindra but will offer my
    40 to 55 HP is a pretty big jump. Mahindra offers a few tractors inbetween. Have you looked at them?? 4530, 5035, 5010....
    Second, 40 HP is pleanty to pull a 6' cutter and 6' tiller. And given it is smaller, it is likely to me more maneuverable. Any other reasons why you are doubting the 40HP machine, or is it only those two implements.
    Third, In general, 4 cylinders are alot smoother operation and seem quieter than the 3 cylinders.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #3
    New Member
    Join Date
    Jul 2013
    Posts
    9
    Thaxton, MS
    JD 4105/5303
    I have looked at them. I really prefer the 4wd gear drive tractors. Simple, plus HST tractors I just dont like. Those are the only 2 PTO implements I will use. I may pick up a 2/3 bottom plow. Not sure yet. I was thinking the 4 cylinder would labor less than a 3 cylinder. Thanks!!
  4. #4
    Gold Member idaho2's Avatar
    Join Date
    Aug 2009
    Posts
    415
    SW WA / North Idaho
    Mahindra 5530 4WD Turbo - Gear,
    rjenkins81,
    I have a 08' 5530 Turbo 4wd and use it on 80 acres and soon to be 100 acres. Every piece of equipment i use with it is HD. I pull 3/16" Ford 3pt plow and not on level ground - eastern palouse. No ballast in tires and the loader is a ML 266 84" bucket. Twin set of remotes for my 10' pull type Mahindra/Kodiak mower and a Bison 96" articulating back blade which could use a third remote. I was raised using Minneapolis Moline, 2N Ford, IH Farmall and John Deere. Compared specs of the 4 majors competitors - line by line - and Mahindra was the winner. Have no issues that required a shop visit. Just performed the 250 hr service and still runs like it was when new.
    idaho2
  5. #5
    New Member
    Join Date
    Jul 2013
    Posts
    9
    Thaxton, MS
    JD 4105/5303
    Thanks idaho2.
  6. #6
    Join Date
    Sep 2005
    Posts
    1,746
    Batavia, NY
    Mahindra -------------
    The 4025 will handle those implements with ease.
    Galen LaWall
    Your Mahindra Tractor Dealer
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  7. #7
    New Member
    Join Date
    Jul 2013
    Posts
    9
    Thaxton, MS
    JD 4105/5303
    I figured with the weight of the tractor that would help as well.
  8. #8
    Silver Member seaneastok's Avatar
    Join Date
    Sep 2012
    Posts
    205
    Panama,Ok
    2012 Mahindra 4530 4x4 ML245 FEL. 58 Ford 861D.65 Ford 4000
    rjenkins,
    Not familliar with the 4025 but I have the 4530 shuttle which I have found to do more than a lot of the previous tractors I have owned or operated over the year's, with higher HP ratings.While I never abuse them,I expect a lot out of my machines.After all, they are tools and I expect them to do the job well.If I was going to use a tool once ..I go to harbor freight.If I am going to use the tool all the time for the rest of my life..I get the biggest and best that will suit my requirements.In my case I have found that my machine is a workhorse.I have pulled,pushed and hooked up to implement's,that while I may have had to slow down my operating preferences down a bit,did the job above what I was expecting.After my experience with my 4530,I believe the 5530 should do all you ask..
    Regard's
    Sean
  9. #9
    Platinum Member EMB5530's Avatar
    Join Date
    Sep 2011
    Posts
    530
    Kansas
    5530 Mahindra 4x4
    I have no experience on a 4025 but do own a 5530 and know that you will have no problem running a 6' brush cutter even in the tallest thickest grass.
    The only bad experience I have had w/ my machine has been an uneducated service department not wanting to listen to my request to check the timing on my machine. The first year I had it I had a little smoking and kinda like a hessitation/sputter but that was fixed by advancing the timing about an eighth of an inch(which is quite easy, wish I would have just done that instead of spending gas money to haul to dealer then get charged by the dealer for adding fuel conditioner and saying there is nothing wrong and charging me for it)
    But to make a long story short the 5530 has been a real work horse and has not given me any other worries in the 260 hrs I have ran it.
    Good luck
    Necessity breeds ingenuity.
    And when your not sure weld it twice
  10. #10
    Member
    Join Date
    Jun 2013
    Posts
    31
    GREER, SC
    MAHINDRA 5530 / 1947 John Deere Model M
    Hey EMB5530, I just bought a new 5530 myself and love it! As you said it is a work horse. My only issue is exactly the problem you had with the smoking and sputter. I have always suspected a timing issue but didnt want to mess with to much stuff since it is brand new and still under warranty. After reading your thread though you said it is quite easy to advanve the timing, could you possibly explain to me how to do this? Could solve my problem and not have to go through the hassle of getting it back to the dealer. Thanks for your help!
Similar Threads
  1. Comparison mahindra 5530
    By tank333969 in forum Mahindra Buying/Pricing
    Last Post: 12-10-2012, 08:26 PM
  2. mahindra 5530
    By steelman0933 in forum Mahindra Buying/Pricing
    Last Post: 11-24-2012, 11:04 PM
  3. Price Check Mahindra 5530 & 6530 ?
    By cederstrand in forum Mahindra Buying/Pricing
    Last Post: 12-20-2011, 02:19 PM
  4. Buying Advice Mahindra 5530
    By FrankBenevento in forum Mahindra Buying/Pricing
    Last Post: 11-27-2011, 02:19 PM
  5. Mahindra 5530 4WD Owner...HELLO!
    By deerklr in forum Mahindra Owning/Operating
    Last Post: 05-14-2009, 09:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
