Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    New Member
    Join Date
    Sep 2013
    Posts
    11
    Strawberry Point
    Mahindra 3315
    Default 3215 Broken bolt in Front Axle
    Hi guys, new here, great site! I saw a post somewhere about the bolts holding the case to the end off the front axle coming lose, noticed a leak under my 3215 & sure enough they were lose & leaking fluid. Raised the front high enough to tighten up & have 1 broken bolt. Can't get at it to drill a straight hole for an easy out so looks like I'm going to have to pull the case off of the axle tube, just wondering if anyone has done it & if they could walk me thru it, thanks in advance!
  2. #2
    Join Date
    Nov 2005
    Posts
    541
    Kansas
    Mahindra 3215 4WD
    Default
    Quote Originally Posted by reward View Post
    I also had a broken bolt on the front axle, but I was able to easily remove it. Most of the bolts on the right side were loose. I did not have to pull the case off. Good luck!!
  3. #3
    Join Date
    Oct 2011
    Posts
    159
    West Virginia
    Mahindra 3550, Kubota L235, Teryx LE, F350 dumper
    Default Re: 3215 Broken bolt in Front Axle
    You may try a right angle adapter for your hand drill. They are relatively cheap. Then you could use an easy out.
  4. #4
    New Member
    Join Date
    Sep 2013
    Posts
    11
    Strawberry Point
    Mahindra 3315
    Quote Originally Posted by Jim Dodgins View Post
    I did try that but the axle tube flares out enough that I still can't drill straight, thanks for the suggestion though.
  5. #5
    Join Date
    Oct 2011
    Posts
    159
    West Virginia
    Is there enough of the Broken bolt sticking out that you can tap it out with a cold chisel, or cut a slot in it with a hack saw blade so that you can put a right angle screw driver on it to back it out?
  6. #6
    New Member
    Join Date
    Sep 2013
    Posts
    11
    Strawberry Point
    Mahindra 3315
    Nope, the bolt is broke 1/2" in, probably the thickness of the flange on the axle tube, I don't see any way but to take it apart.
  7. #7
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,713
    Foster, RI
    Mahindra 3016
    Is this the front end they put on the 3016 as well? If so, where are these bolts holding what case? What is being considered "the case"? Pivot shaft assembly? Front drive housing?
  8. #8
    New Member
    Join Date
    Sep 2013
    Posts
    11
    Strawberry Point
    Mahindra 3315
    I am not sure if it's the same, from what I could gather from a parts diagram online this is the case bolted to the end of the axle tube that the tire bolts to, if that makes sense. It has front wheel assist, I saw a post on here that said it was common to have the bolts come loose, I'll see if I can find it. I am just wondering if I can unbolt it, pull the case off far enough to remove the broken bolt, & then bolt it back.
  9. #9
    Approved Advertiser
    Join Date
    Nov 2002
    Posts
    369
    Bethany, CT
    Mahindra's
    Just remove the other bolts and it comes apart.
  10. #10
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,713
    Foster, RI
    Mahindra 3016
    This is what is on the 3016 and 3616 front end 4wd casing wise. Are you meaning the bolts that are visible holding the 4wd housing to the axle? Anyone know the torque specs for these ?
    Attached Thumbnails Attached Thumbnails 3215 Broken bolt in Front Axle-pa033302-jpg   3215 Broken bolt in Front Axle-pa033304-jpg
Similar Threads
  1. Front Axle Pivot Bolt
    By deadhorse in forum Kubota Owning/Operating
    Last Post: 12-06-2012, 08:18 AM
  2. BX Broken front axle
    By V1Rotate in forum Kubota Owning/Operating
    Last Post: 08-19-2012, 07:57 PM
  3. 790 front axle broken
    By godaddy in forum John Deere Owning/Operating
    Last Post: 03-23-2011, 06:26 AM
  4. 2815/3215 Front Axle Issue
    By Sergei in forum Mahindra Owning/Operating
    Last Post: 07-19-2009, 08:42 PM
  5. 7800 broken axle bolt
    By B7800mike in forum Kubota Owning/Operating
    Last Post: 06-21-2008, 11:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
