Results 1 to 2 of 2
  1. #1
    Member
    Join Date
    Feb 2012
    Posts
    31
    Dayton, TX
    Mahindra 4025 4wd
    Default 4025 4wd max disc harrow size
    I have a 4025 4wd with a loader that I'm wondering of I can pull a 8' 24 blade disc with. Im not sure how tall the discs are but they are notched and the whole disc is supposed to be about 1100lbs. Id like to able to run it offset as well to really churn up some soil I havent disced up already. My soil is sandy loam and Im planting some sprigs next month and want to upgrade from the 5' disc I borrowed from a friend. Thanks.
  2. #2
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,968
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    Default Re: 4025 4wd max disc harrow size
    From your description you are likely looking at a 24/20" or 24/24" Tandem Disc Harrow. You will be able to pull either size behind your Mahindra 4025/4-WD. A 24/20" Tandem Disc Harrow, in theory, should till 9" deep after several passes over the field; probably 7-1/2" in the real world. A 24/24" Tandem Disc Harrow will till slightly deeper.
    Disc Harrows of this pan diameter USUALLY have 9" spacing between pans and USUALLY have Category I/II hitch compatibility.
    Following link should help you to make an informed decision once you have determined actual pan diameters and pan spacing:
    http://www.tractorbynet.com/forums/a...n-18-45-a.html
    The word tractor was taken from Medieval Latin, being the agent noun of trahere, "to pull, draw".
    Kubota B3300SU; no longer with me but still pulling in the community.
Similar Threads
  1. Disc harrow disc size question
    By RancherSam in forum Attachments
    Last Post: 11-15-2007, 09:35 PM
  2. What size disc harrow for a TC30?
    By bootstraps in forum New Holland Owning/Operating
    Last Post: 08-16-2007, 04:46 PM
  3. NEED GUIDANCE ON SIZE OF DISC HARROW
    By inveresk in forum Attachments
    Last Post: 03-03-2006, 10:22 AM
  4. Tractor Sizing What size disc harrow?
    By beefkiller in forum Yanmar
    Last Post: 08-19-2005, 10:14 PM
  5. What size disc harrow should I Buy?
    By Anonymous Poster in forum New Holland Owning/Operating
    Last Post: 12-07-2001, 12:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
