Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Feb 2015
    Posts
    2
    Edmond, OK
    Mahindra 2810
    Default 2810 FEL Fluid question
    Hello. New to the board and new to Mahindra. Recently purchased a 2810 with front end loader. The fluid level through the site glass looks fine, as does the color. My question is this - is the rear end hydro fluid the same that operates the front end loader - as in is this site glass the one and only place to check fluid levels (other than engine oil)? Or is there another fill and check location for the loader fluid? Thank you for any assistance.
  2. #2
    Join Date
    Jul 2014
    Posts
    2,274
    Guin, AL
    Kubota L3200 DT w/LA524 FEL, Loaded rear tires, LP RCR 1860 5' Cutter, LP RTA 1258 5' Tiller, LP PFL 2042 Pallet Forks w/60" Extensions, KK BB60 Box Blade, KK PHD-12" Post Hole Digger
    Default Re: 2810 FEL Fluid question
    To the forum from Alabama. Yes, if you have 2 WD and no if you have 4WD. The front axle is separate on 4WD.
    US Air Force Retired (1966-1988) ... mike
    Kubota TG1860G w/RCK54TG
    24 HP V-Twin Pro Yard Tractor
    Ohio Steel 12.5 cu. ft. Poly Swivel Dump Cart
  3. #3
    New Member
    Join Date
    Feb 2015
    Posts
    2
    Edmond, OK
    Mahindra 2810
    Quote Originally Posted by mddorange View Post
    Thanks from OK. I do have 4 wheel drive, so front axle has its own? Are the front end hydraulics plumbed with the rear diff and trans?
  4. #4
    Bronze Member Blue_Sky's Avatar
    Join Date
    Oct 2009
    Posts
    87
    Lower Alabama
    2006 2615 4WD Mahindra
    L.A. - lower Alabama here/
  5. #5
    Join Date
    Jul 2014
    Posts
    2,274
    Guin, AL
    By frontend, do you mean loader? Yes the loader works off the backend hydro.
  6. #6
    Super Member teg's Avatar
    Join Date
    Jul 2005
    Posts
    5,733
    Raleigh, NC Hillsville, VA
    L2800 - HST
    Quote Originally Posted by Okiebob View Post
    ...My question is this - is the rear end hydro fluid the same that operates the front end loader - as in is this site glass the one and only place to check fluid levels (other than engine oil)? Or is there another fill and check location for the loader fluid?...
    Yes, FEL, power steering and HST (if you have it) come from the same location. The front axle (4x4) has it's own fill / drain plugs and should be checked also.
  7. #7
    Join Date
    Nov 2014
    Posts
    1,412
    Texas
    Mahindra
    This all if you have a Mahindra loader on it and not an alternative loader.
    Some things I would check is turn the pto on and be sure its working... also be sure the 4wd lever is operating correctly. Fuel filters are neglected on these models the most for some reason so make sure and check it as well
Similar Threads
  1. Replies: 3
    Last Post: 10-20-2014, 04:40 PM
  2. Branson 2810 - Leak at Fluid Level Check Window
    By coolbowfin in forum Century & Branson
    Last Post: 04-25-2011, 04:30 PM
  3. 2810 with FEL
    By capi75rs in forum Mahindra Owning/Operating
    Last Post: 03-07-2009, 12:35 PM
  4. 2810 FEL
    By capi75rs in forum Mahindra Buying/Pricing
    Last Post: 12-12-2008, 09:26 AM
  5. More FEL lift cap. on a 2810 HST?
    By MDM in forum Mahindra Buying/Pricing
    Last Post: 04-26-2008, 08:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
