my 4110 has about 1000 hrs. The big tires are wearing in center. Air pressure is right. No weights, water or loader Mostly pull mower, hog and box blade.
Should I take some air out of tires to wear them more even?
Cheers..... coffeeman
I've always run the rears at 11 psi on my 4110 for ideal contact and wear. My rears are filled to 3/4 full with methanol/water mix. I have run a fair bit over the years on pavement too, travelling to jobs a few miles away - the rears do fine but the fronts wear a little quicker as I run them hard (38 psi) for loader use at any time.
Hi there,
Checked tire pressure and shocked till I came back to TBH and read replies. My tire about 9 lbs, other 6 lbs . I have, I believe,
Titan made in USA industrial tires. No water no weights. I was shocked to see American tires. Now I like my mahindra a little more. Of course if
I could have gotten a good old USA tractor I would choose that as long as I can afford. On some items I believe it's cheaper in long run to
buy USA.
Cheers......Thanks for replies.
Coffeeman
