Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    New Member sawduster2's Avatar
    Join Date
    Jul 2016
    Posts
    10
    Lexington
    Mahindra 3525
    Default 3525 Electrical Died During a Pit Sto (Tier 2)
    I was brush cutting this morning for 2 hours, all was normal and tractor ran well and all gauges were in the normal range. Air temperature was around 80 degrees when I stopped for a drink of water and returned to tractor about 30 minutes later. Tractor wouldn't turn over and further checking showed that no electrical was working, no lights, horn, turn signals, no 4 way flasher etc. I checked PTO & trans range 4 times to make sure a safety switch wasn't open. I pulled and checked all fuses on dash panel & all were fine. I looked under the hood for a relay or fuse and couldn't locate any. I checked behind the dash and see if any hidden relays were and found what looks like a relay but I believe it is the Beru warming timer relay (0201010077). The electrical schematic shows a "maxi fuse" between the alternator & starter but I traced the wiring and see no fuse. I cleaned the battery terminals, no improvement. I left the tractor in the field and removed the battery and took it to an auto store where it tested fine (12.86 v & 1032 CCA). With no electrical device working I believe I have a blown fuse or relay somewhere. Any suggestions where to look? I do not have a "fan" switch on the dash as was mentioned in a previous post.
    Any suggestions are greatly appreciated.
    I've added photos of left & right side of motor.
    3525 Electrical Died During a Pit Sto (Tier 2)-3525-left-side-jpeg
    3525 Electrical Died During a Pit Sto (Tier 2)-3525-right-side-jpeg
  2. #2
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    7,685
    Central Square, NY
    LS XR3037HC
    Default Re: 3525 Electrical Died During a Pit Sto (Tier 2)
    When you removed the battery did you check the hot plus side wire for fuses. Some tractors have a main fuse at the battery. Also, check the ground cable where it attaches to the frame.
  3. #3
    Join Date
    Jul 2016
    Posts
    10
    Lexington
    Mahindra 3525
    I traced the hot wire from the battery to where if I remember correctly was connected to the starter? Anyway, no fuse was observed.
  4. #4
    Join Date
    Feb 2005
    Posts
    7,685
    Central Square, NY
    LS XR3037HC
    Check post 9 of this thread. Many suggestions were offered but post 9 seemed to fix the problem.
    By the way, Welcome to TBN...........
    http://www.tractorbynet.com/forums/m...ra-3525-a.html
  5. #5
    Join Date
    Jul 2016
    Posts
    10
    Lexington
    Mahindra 3525
    I reviewed your previous post from my smart phone out in the field and was hopeful but as I mentioned in my post I do not see any fuse or fan icon on my tractor dash. I have the fuse panel but I don't see any other possible fuse locations. Is it possible that fuse you refer to is on the firewall side of the panel?
  6. #6
    Platinum Member mjw357's Avatar
    Join Date
    Jan 2011
    Posts
    559
    The Sticks, Ohio
    Kubota B3200
    Perhaps it's the ignition switch?
    Kubota B3200 with LA504 FEL and Woods HC54 brushhog
    Looking for: Pallet Forks
  7. #7
    Join Date
    Feb 2005
    Posts
    7,685
    Central Square, NY
    LS XR3037HC
    Quote Originally Posted by sawduster2 View Post
    He stated the location was under the dash on the left side. Maybe under a cover? I assume the fan icon is on a relay or fuse in that area.
  8. #8
    Join Date
    Jul 2016
    Posts
    10
    Lexington
    Mahindra 3525
    Tractor still stranded in the field & I'm still stalled on finding a possible "maxi" fuse that the dealer and manual claim is between the starter and alternator (I see no fuse that is physically between the starter & alternator). I reinstalled the battery, cleaned the posts and clamps, snugged the ground to frame & removed the ignition switch and had no current to the switch. No lights or accessories work.
    3525 Electrical Died During a Pit Sto (Tier 2)-20160725_203206-jpg 3525 Electrical Died During a Pit Sto (Tier 2)-3525-dash-right-jpg 3525 Electrical Died During a Pit Sto (Tier 2)-3525-dash-left-jpg 3525 Electrical Died During a Pit Sto (Tier 2)-3525-relays-under-dash-jpg
    I've attached photo's of my dash and unlike a previous post suggestion there is no "fan" icon housing a fuse. As darkness was advancing last night I noticed a couple of relays that are housed under the dash panel (floor level) on the left side. There is a band of gray trim between the transmission and dash as can be seen in the 3rd photo. I plan to remove this "trim" and see if I can find a fuse in this area.
    My local Mahindra dealer has no idea where the fuse is and he called Mahindra USA in Texas and all they provide is there is a 30 amp fuse between the starter and alternator as show on the electric schematic. The dealer is willing to come and pick up the tractor but I shouldn't have to spend $500 to find a fuse on this tractor.
    Anyone else have a suggestion where to look for a main 30 amp fuse on this 2007 Mahindra 3525 Tier 2 tractor (230 hours)?
  9. #9
    Platinum Member ozley's Avatar
    Join Date
    Mar 2005
    Posts
    676
    TN
    LS U5030C
    Default
    It is usually on the wire to the starter on some tractors. If it there look for a bulging spot in the wire all taped up. It would be under the tape not looking like a fuse at all.
    LS U5030C, International McCormick B-414 Gas
  10. #10
    New Member
    Join Date
    Mar 2009
    Posts
    7
    Quote Originally Posted by ozley View Post
    The 30 amp fuse is on the left side of tractor, looking at the dash from seat, below the instrument gauge cluster. It is not in the main fuse block. It blew on my tractor when it was new, I replaced it and 700 hrs later no problems.
Similar Threads
  1. Current 3038 Tier 4 Interim or Tier 3?
    By SnPaC in forum LS Tractor Buying/Pricing
    Last Post: 04-01-2015, 12:44 PM
  2. Kioti 45 died while operating - likely electrical problem
    By BigGuy in forum Kioti Owning/Operating
    Last Post: 08-26-2013, 12:36 AM
  3. 3525 Electrical Issue
    By michaellacombe2 in forum Mahindra Owning/Operating
    Last Post: 05-26-2013, 09:51 PM
  4. 4310- died in a puff of smoke! Electrical?
    By Newfman in forum Parts/Repairs
    Last Post: 08-18-2012, 09:45 PM
  5. Are you Tier II or Tier III or ITIV or really Tier IV??
    By AKfish in forum John Deere Owning/Operating
    Last Post: 07-18-2011, 02:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
