mike35549
How wide is the 2538 with R4 tires on it. I know the specs says it is 60" wide but would figure it would be a little wider with R4's. You see these packaged with 5' and 6' implements just trying to figure out which is the better fit 5' or 6' if getting a cutter and box blade etc. seems you would want one as wide or a little wider than your tires.
