Hello gtmahindra,
My dad had the same problem with his eMax 25 HST. First the dealer replaced the fuse. It worked for a bit then it blew the same fuse two more times. He had the dealer pick it up again. The dealer replaced the entire wiring harness for the tractor. I did not get to see the location personally, but the PTO shaft had wore through the harness and into the wiring. It was causing a short (if I remember correctly) and causing that particular 7.5 amp to blow. Our dealer had the same thing happen to another eMax tractor. When the dealer replaced the wiring harness on the eMax they tried to make sure that the same thing would not happen again. I think they may have rerouted the wiring harness in the tractor somehow. Like I say I did not get to see it in person. While the eMax was being repaired my dad decided to trade the eMax in and get a Max 26 XL instead. The eMax was sold in less than a weeks time, and last I heard the new owner was pretty happy with it. I hope this may help some.
