tracydj
I had a weld break on my 2538 backhoe bucket which in turn pushed the supports on the back side through the metal on the inside of the bucket. I took the bucket to a friend that is a metallurgists with a large local steel fabricator. He said the if the weld wouldn't have broke then none of the other damage would have happened. He said that it was defiantly a manufactures defect and that it should be covered under warranty. You can see in the attached pics where the 10" of a weld pulled away. From what I have read the tractors backhoe should never have enough power to break a weld on a bucket. Have any of you experienced any issues like this and were you able to get the dealer to cover under warranty? Thanks in advance for the input.
