JerryK
Elite Member
- Joined
- Feb 21, 2004
- Messages
- 3,266
- Location
- Vanderbilt, Michigan, USeh?
- Tractor
- Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Just got done adding a length of 2-1/2" I.D. [ woodworking dust collector hose ] hose to my air filter. I relocated the horn to the upper right. I also relented and went from a 12" holed radiator blocking foam board to a 7-1/4". The air filter was sucking in snow and getting the outer filter wet. Actually had fine snow packed into the outer casing of the filter. Now the filter will source it's air up high under the hood away from the fine snow getting sucked thru the hood screens at full throttle. The smaller radiator hole will cut down on the snow flow, too. Anywhilst, next time it snows I will let you know....
