gardner175
I have a new 4550 4wd manufactured in 2014. It has been great so far with a few things that needed tweaking. We continue to have problems with condensation on the inside of the instrument cluster cover. I attached a photo. The whole instrument cluster unit has been replaced and it still happens. The condensation is on the inside. It occurred when temps were in the 80s and when they were in the high 20s. It begins to develop after I have run the tractor about 20 min and goes away (not visible) when the tractor cools down. No condensation is visible when the tractor is not running, The tractor sits in my machine shed and is protected from the weather when I am not using it.
Has anyone else had this problem with their 4500 Mahindra, or any other model? The Mahindra tech rep has said this is not normal and they will again replace the instrument panel. I am just trying to get ahead of this in case it keeps happening. I am totally stumped and suspect if it is a parts problem, I am not alone and someone very skilled or clever may have a solution. It is a great tractor so far, this issue is just an itch that is hard to reach and I would like to scratch it.
