Petrol and Powder
Member
So I did some mowing today with the mid mount mower. When I was done there was still some daylight and I decided to sharpen the blades. Purchased the tractor and mower last Spring and this was the first time I did any maintenance on the deck.
HOLY COW those bolts are tight !
3/4" drive 18" breaker bar with about a 4' section of 1" pipe on the breaker bar just to get those puppies loose. The Impact wrench wouldn't even begin to break them loose.
When I was done sharpening the blades I put them back on with just the breaker bar. I put a little anti-seize grease on the threads before re-installing the bolts.
Anyone else have this problem?
Also, could only find 4 zerk fittings ; one for the idler pulley pivot, one on each U-joint for the drive shaft and one for the splined center section of the drive shaft. Is that all?
