Add weight.
I use four weights about 120 lb each with my 7-ft offset disc behind my Mahindra 5525.
An offset disc (two axles in a V-configuration) is a primary tillage implement for use on unplowed ground.
A tandem disc (4 axles in an X-configuration) is a secondary tillage implement for use on plowed ground to break up the clods.
Good luck
Add weight.
Good luck
