SDCouch
I have a 1538 Shuttle (w/FEL) and just recently the Engine Malfunction light started blinking. This was accompanied by a loss of power when the tractor is under a load - like when back-dragging with my root grapple. The engine runs, but throttle response is slow and when going up a hill it will loose RPMs. This was not a gradual thing, it was a sudden thing.
Thinking that it might be a clogged fuel filter (or something of that nature) I replaced both filters. When I removed the primary filter, I discovered it was that cheap paper filter and it seemed to be starting to denigrate. There were a few small pieces of it in the bottom of the bowl. After cleaning that out and replacing it with a much better filter, and replacing the filter/water separator, I was hoping that was the issue. Unfortunately that did not help. There seems to be no residue in the tank (it was drained to replace the filters).
Am I stuck now with removing the entire fuel line and pumps? How much of a job is that? Are there any other suggestions anyone might have before I undertake all this? Any help or direction is appreciated.
