Lew3616
Have a question, I have a 3616 with the 66" SB66 front mount blower, I have had to replace the gearbox input shaft 3 times in the last 2 years, it broke again only after 5 hrs of running time, this will be number 4, it breaks where the shaft steps down for the steel worm gear. Dealer says I wasn't running it at the correct rpm, so I ran it at his recommended rpm, I broke a shaft, then he says I need to run his shear pins, and thats why it breaks the shaft, the first time it broke I was running his shear pins. When I got the blower new, the drive shaft was out of balance, he replaced it, a few weeks later the bearings all came loose, nothing but problems with this blower. Any ideas of why the shaft keeps breaking? Thank You.
