tbzep
- Joined
- Jul 4, 2008
- Messages
- 92
- Location
- TN
- Tractor
- 1948 Farmall Cub, 1952 Ford 8N, 1962 Ford 861 (sold), 2015 Mahindra 3550, 2017 Gravely ZT HD 52
I've actually had it just a bit over two years, but here's the skinny on my 3550 PST. I am not seeking solutions to my issues. It's just an honest review of a modern tractor after spending my whole life on classic iron.
1. Whatever was used to lube the shuttle lever hates cold weather. When it's below freezing, I can barely move it...to the point I'm worried about breaking something. I've lubed it with oil when above freezing, hoping that it would wash away whatever is getting so stiff. No joy so far. It's like butter when the temps are above freezing.
2. Those light pods mounted on the ROPS are targets for tree limbs. They stay busted. I've epoxied them back together only to get 'em smacked down again. Buying new pods is out of the question. Evidently they are made of platinum instead of plastic. I've come to the point that I'm just going to remove the lights compeletely this spring. I've been thinking about adding LED's to the inside of the FEL (for protection) and cross the beams (not Proton Pack streams, so I think it's safe) to get some peripheral lighting.
3. Temperature gauge quit working. I'll get around to troubleshooting it one of these days.
4. My OBD scan tool will not reset the maintenance indicator. I'm tired of seeing the little wrench flashing.
5. R4 tires are fun in the heaved winter mud and manure. I pretty much drive sideways on mild slopes with or without a bale of hay.
6. 4WD is a must when putting out large round bales. I don't have room in the barn to maneuver with the bush hog attached, and have near zero traction with the rear tires without its added weight. I'm pretty much in front wheel drive. And to think, the biggest reason I got the Mahindra was because it was considerably heavier than anything else in it's class and price range. I'd hate to see what those other light-weights would be like!
7. I've commented before that transmission/hydraulic filter maintenance is not the easiest to fool with. Thankfully, it doesn't have to be done often.
8. How the heck have I lived and worked for so long with FEL-less tractors? That thing is so versatile it ain't funny. Rescue a stuck heifer, dress a deer, pull up posts, clear thickets, trim trees, (shhhh, don't tell OSHA). You name it...and then there's the traditional dirt moving and hay spear stuff.
9. All the modern tractors have you sitting on top, more or less on a platform. With my old 8N and 861, you straddled the drive train, lowered your CG, use your legs to absorb some shock when needed, and allowed you to keep your head from being the main target for every human hating tree limb on the planet. I'm not fond of sitting way up on top of the tractor.
10. Modern tractors (I sat on many brands/models before buying) are designed for somebody with legs about a foot shorter than mine. To steer comfortably and still have my feet at the pedals, I have to scoot the seat up and my knees are dang near under my armpits. To have comfortable legs, I have to scoot the seat back and lean forward like riding a Harley with ape hangers. I can't have it both ways. And, yes, the steering column is tilted as far back as I can get it. :/
11. When I crawl under the tractor there are hoses and crap sticking out everywhere. I'm amazed that I haven't torn something loose in the 2+ years of ownership. Crawl under an old classic Ford tractor and you see nothing but cast iron and big ole' bolt heads! Now that's a tractor that's ready for rough action! Bury it past the belly pan? No problem. Drag it out and get back to work! I'm betting other classic iron with green, red, or orange paint is the same way. Do that on a modern tractor and you'll probably be fixing stuff for a week before you can work it again.
12. I'm pleasantly surprised the DEF-less tier IV is still running clean and strong. While the barn isn't air tight, it is stuffy enough that I won't stay in there with the gas burner more than a couple minutes before it lets me know I'm stupid for being in there. The Mahindra burns so clean that I really have to pay attention to how long I'm in there with it because I don't notice the exhaust at all.
13. Coons love to walk on my tractor. Thankfully, they use the hay bales for bathrooms. I've got to get that trap set.
