Quick Hitch Questions
   / Quick Hitch Questions #1
CoachEarl
Member
Falls City
Mahindra 2538 HST
I am looking at the HF Quick Hitch. (yes, I have searched the many threads) I have a 2538 with the Mahindra Box Blade and Mahindra Shredder I got in the package deal. What all do I need to adjust it to fit both of those implements? Do I need the top link adapter and do I need adapters for the bushings on the implements?
   / Quick Hitch Questions #2
If they're new then they are probably quick-hitch ready so you shouldn't need top link adapters. If you don't put adapters on the bottom pins of the implements they will still fit but will be sloppy. The HF quick hitch has an inherent problem with the top hook being too close to the bolts that hold it. Some implements will fit and others hit the bolts. No way to know without trying.
I bought one of these hooks for mine but many other people have just modified the HF hook (see youtube).
Amazon.com: TOP HOOK FOR CAT 1 QUICK HITCH: Industrial & Scientific
   / Quick Hitch Questions #3
I bought this optional upper-link part from HF, used it once, decided it wasn't needed.
I now use a loop of chain around the top of the Qhitch and around the top of the mower's front tower. That allows flex at that location as I go up & down terraces etc.
This optional 'Quick Hitch Top Hook' described by TractorNH solves the problem of the implement tower bumping the Qhitch's bolt shoulders, by spacing the hook farther out from the bolt holes.
I just did a search. 'SMA' seems to be the only supplier of this version but nobody presently stocks them. If anyone can recommend a source I'll buy one!
And here's my HF Qhitch with its native hook. With the bolt holes so close to the hook instead of to the front of the hook, most implements conflict with the bolt-hole shoulders.
This also shows the removable, adjustable pins I use in place of bolts. Sometimes mounting the hook upside down is the simplest way to hitch to an odd implement. I discussed that in this old thread.
475243d1469142470-pats-quick-hitch-vs-northern-kimg1766rqh-toplinkpins-jpg
   / Quick Hitch Questions #4
You asked about adjusting the HF Qhitch, and sleeves for the implements.
Some people find their implements are made to a different width than the Qhitch and have to add spacers at the implement pins to make the implement wider, or, use a Farm Jack to make the Qhitch a little wider or narrower. There doesn't seem to be any adherence to the 'standard' dimensions of the original John Deere Quick Hitch.
Sleeves on the implement pins? The fit is a little sloppy without them but I don't use them, I don't put enough hours on the Qhitch to wear out the lower hooks or the easily-replaced implement pins. In commercial service, sure, but I prefer to avoid the added complexity. Also, you don't need lynch pins, clips, on the implement's pins because the Qhitch is fixed width.
   / Quick Hitch Questions #5
I took out the two bolts and cut roll pins to length so they do not stick out
Thanks for all of the info. I’m goint to try to make this thing work. Keep the ideas coming!
   / Quick Hitch Questions #7
I use the optional top link almost exclusively.
   / Quick Hitch Questions #8
I also. After two years I have modified my hook but I notice that I end up having to raise and lower it enough times that I could just stay with using the adaptor. IMG_2619.JPG
By the way, can anyone tell me what that 2nd hole in the adaptor is used for? Inquiring minds want to know!
The outer hole on the "U" is self explanatory. The inner one I haven't figured out what it's supposed to be for yet after 2 years.
   / Quick Hitch Questions #9
The Agri Supply QH comes with the top hook that extends out some. I use the top link adapter on my finish mower but I have to use a piece of chain on my brush cutter. I have modified everything else to fit the QH with the hook set in the lowest position. I cut off a couple of bolts and drilled them to hold the top hook. I stick a long cotter pin through both pin holes and give it a little bend so it won't come out and is easy to remove.
   / Quick Hitch Questions #10
I got mine here,,, but, they are out of stock, also,,,
https://qualityfarmsupply.com/search?q=873-HF141137
I guess I could sell my hook for,,,oh,,, say,,, $200,, FREE SHIPPING!! :thumbsup:
:laughing:
I have no idea why that hook is so hard to get,, :confused:
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
19015 (A55788)
19015 (A55788)
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
NEW Fork Extensions (A59000)
NEW Fork...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
TANK SEEDER (A58214)
