The actual cup holder is a piece of 6" pvc pipe. When I got my tractor, the company left in the toolbox the mounting covers for the
FEL. Why I used it, is it's just a little bit wider than the
ROPS, I could utilize the two studs that were on each side. this would cause it to wedge and not slip when mouted to the
ROPS. I welded two 1/2" bolts to the end of the studs. Then I took a piece of 3/8 x 1/2"x 6" drilled holes in it so it would line up with the bolts I welded to
FEL bracket. On the other side of the bracket that would support the cup holder I welded another 1/2" bolt to the center of the bracket. I then took a piece of flat steel 3/16" x 1 1/2" x 11 5/8" heated it up and bent it so it will support the PVC pipe and be mounted to the 1/2" bolt. I used 1/4" bolts to attach the steel to the PVC Cup Holder.
