Results 1 to 7 of 7
  1. #1
    Join Date
    Jun 2005
    Posts
    4
    New Hampshire
    Default 3 point hoe
    I've been looking at a 2810 at a Mahindra dealer in VT and he's trying to sell me a 8' BH on a 3 point hitch. He says the 2810 doesn't need a sub frame BH. He also says Mahindra has no intention of discontinuing the "10" series. Is he correct or should I look for another dealer?
  2. #2
    Platinum Member Tim_in_IA's Avatar
    Join Date
    Feb 2005
    Posts
    808
    Eastern Iowa
    Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
    Default Re: 3 point hoe
    every mounted backhoe needs a subframe mount unless you want to risk having two halves of a tractor instead of 1 functional tractor. [img]/forums/images/graemlins/smile.gif[/img] A backhoe can lift the whole tractor off the ground easy. You don't want that kind of stress not being distributed across the whole machine.
  3. #3
    Approved Advertiser
    wallace's Avatar
    Join Date
    Feb 2004
    Posts
    2,953
    PA.
    MAHINDRA
    They are not discontinuing the "10" series just certian models
    The 2310 and 2810 will be replaced by the 3510 which is the same tractor just more hp.
    The tractor is by far heavey enough to handel the 3 pt hoe
    Although the tractor manufacture might not stand behind the warranty the backhoe mfg should.
  4. #4
    Join Date
    Aug 2003
    Posts
    186
    Florence NY
    Mahindra 2015 w/FEL
    Well, I don't have a backhoe [img]/forums/images/graemlins/frown.gif[/img] but it seems if there's one thing the overwhelming majority of TBNers agree on, it's that a tractor mounted hoe, no matter the brand, no matter the model, should have a subframe.
    A tractor is a big investment. There are subframe mounted backhoes available for the 2810. Why take a chance when you don't have too? To save a few bucks? What's piece of mind worth?
    Just my .02
  5. #5
    Join Date
    Jun 2005
    Posts
    67
    Mahindra USA does not recommend the use of a 3-point backhoe. Using a non-Mahindra backhoe may void the warranty.
  6. #6
    Approved Advertiser
    Join Date
    Nov 2002
    Posts
    369
    Bethany, CT
    Mahindra's
    <font color="blue"> I've been looking at a 2810 at a Mahindra dealer in VT and he's trying to sell me a 8' BH on a 3 point hitch. He says the 2810 doesn't need a sub frame BH. He also says Mahindra has no intention of discontinuing the "10" series. Is he correct or should I look for another dealer? </font>
    - Go with the subframe mount 3375, its a real nice set up, pull 2 pins and 2 quick couples and the hoe is off. It will save you alot of headaches in the long run. Just the time it saves mounting and dismounting the hoe. Also Non Mahindra backhoes/3 pt backhoe can void the warranty. We have heard from a few people that have bought Mahindra's from up that way with 3 point mounted red bradco's and ended up adding the subframe after the fact.
    As far as the 2810 being discontinued the HST version has been, but I have not heard the gear version being discontinued.
  7. #7
    Join Date
    Jun 2005
    Posts
    8
    Jp, Please email me privately at marc04@adelphia.net I might have the setup you want....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
