Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2003
    Posts
    151
    Westford, Vermont
    Mahindra 6500
    Default 6500 Starting Problem
    Does anyone know where the neutral safety switch on a 6500 is located? (The switch on the forward/reverse shifting lever linkage.) Starter won't engage. I can start it by jumping from solenoid to starter. I followed the shift (forward/reserve) shifter linkage to where it enters the transmission. I didn't see a safety switch. I did located the safety switch for the pto.
    Bob
  2. #2
    Join Date
    Jul 2003
    Posts
    1,926
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    Default Re: 6500 Starting Problem
    Do you have 2 or 4WD? If 4WD you have a shuttle shift and it must be in the "neutral" center position to start no matter where the gearshift lever is). If you can jump it from the solenoid to the starter, it sounds like the solenoid is bad or the switch from the key to the solenoid. Do you hear the "click" when you hit the key start??BobG in VA (PS reason on the 2WD is that shuttle shift is not available with 2WD).
  3. #3
    Gold Member Maine_Polack's Avatar
    Join Date
    Nov 2004
    Posts
    361
    Central Maine
    Mahindra 6500 4WD
    I dunno. I'm looking in the parts diagram, for starter, Alt. and Dash Instruments, (all on the same page). The Neutral safety switch is located smack in the middle of the page, with no indication of it's location.
    I'm probably missing something. Also looked in the service manual. Quite elusive.
  4. #4
    Bronze Member turbinesurgun's Avatar
    Join Date
    Sep 2004
    Posts
    82
    i have had the same problem a piece of brush would knock the wires off. It is towards the back of your right floorboard. It has a rubber boot with 2 wires i believe. the switch has more than two prongs so yo may have to play with it a little while to get it to work, but this should help
  5. #5
    Join Date
    Oct 2003
    Posts
    151
    Westford, Vermont
    Mahindra 6500
    The problem turned out to be the pto safety switch. I fiddled with the wires and it started. I'd still like to know how the neutral switch on the reverser works (and its location).
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
