#1 (permalink) |
Gold Member
Hi all
Can anyone guess if this sounds ok. When cruising along with rotary cutter running I hear a whine in pto. About 1/2 speed not much load hit a bump and err..err..err...err...err. Sounds like an old manual trans pickup as it lobs over a hill and sort of coasting on level. When I shut pto off it quits, so I guess it's pto. I can't remember if this is normal as of last year. I can't find tractor manual to check if I missed some oil check point. I'll have to look for it as they are expensive. Cheers...Coffeeman |
#2 (permalink) |
Gold Member
Hi all
#5 (permalink) |
Gold Member
Coffeeman,
I second the hydraulic fluid level check (rear end). My 3510 (same tractor, smaller motor) just started the same thing. When PTO all the way up, some whine, especially when unlevel. I checked the fluid, it is low. Not out, and whine goes away when lowered slightly and top tilt cylinder closed. It just happened and I checked the fluid (while running) and parked it. I'll put fluid in it as soon as I get the chance. Sort of like the whine power steering makes when low.... -DiskDoctr |
#6 (permalink) |
Gold Member
Coffeeman,
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
