HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-23-2006, 06:46 PM   #1 (permalink)
Gold Member
Default 4110 Changing front axel oil
Probably the first mistake I made is consulting operator manual.
Book says: 1. Drain oil from left and right drain plugs.
2. Replace and check plugs.
3. Fill with new oil to the correct level in the filler hole.
Book calls for 2.32 gal oil. The tractor has what I believe to be a check over flow hole toward the top of left front axel. Put in a little over 2 gal oil, but not 2.3 gallon. Oil flowing out of upper plug. I am gussing the over flow plug is full mark. The book doesn't indicate that. But the oil is in there. Now I'm guessing the extra oil is called for to fill small space in front pumpkin for front axel drive. I noticed a little drain plug on the pumpkin. Probably the most important part to drain as any shavings might lay there; the lowest point. Book doesn't mention this. Anyway, I was wondering if anyone knows about this. Also, I think I might have over filled by about a tenth or two of a gallon. I guess this shouldn't hurt in front axel? Of course oil is cheaper than bearings and gears. But, many things break because of too much oil and grease.
Cheers...Coffeeman
coffeeman is offline   Reply With Quote
Old 07-23-2006, 08:30 PM   #2 (permalink)
Default Re: 4110 Changing front axel oil
i wouldnt worry to much, just fill it to the level plugs, i have a 5500 fwd, i changed the oil in the transmission, and put 9.75 gals of oil in it, the book says it hold 6.3, and i fill it to the same mark on the stick as of before i drain it.
__________________
5500 4WD
22' Goose Neck trailer
Mohawk 7' cutter
ARMSTRONG 6' BB
Bail spear
9" & 12" Augger
6' Angle tilt grader blade
J.D. Zero Turn-465 62" Deck
New 07 Dodge 1-ton dually, 6.7L,
tractorboy5500 is offline   Reply With Quote
Old 07-25-2006, 03:14 PM   #3 (permalink)
Gold Member
My 4110 has the lower drain plugs in each hub unit as well as the upper plugs which are where the oil level is supposed to be. When I change mine, I always drain the differential housing too. I like to run my oil level higher than what the plugs will allow you to fill to, I fill mine until it almost covers the axle when looking down the fill tube on the banjo housing. I don't think the level is high enough in the differential housing when you go by the plug level, especially on alot of hilly terrain, so I run it higher. Doesn't hurt a thing in a low-speed diff. in a tractor, just a little extra 90w. This way I'm sure those pinion bearings keep oil.
__________________
Mahindra 4110, FEL w/5' & 6' QA buckets & forks, 6' Atlas boxblade, 6' Howse rotary, Leinbach PHD w/9" & 12", 1 bottom plow, MF 2/3 bottom plow, 20"x6' bog disc,TSC subsoiler, TSC middlebuster, 6 ton Anderson 12' dump trailer, 20' Hurst 14k flat trailer.
skipmarcy is offline   Reply With Quote
Old 07-26-2006, 10:51 PM   #4 (permalink)
Gold Member
Quote:
Hi Skip
That's exactly what I drained, except the housing. Should have though. Also filled to just around axel as you peer in. Next time I'll do housing.
Cheers...Coffeeman.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
