Slippy
- Joined
- Sep 23, 2002
- Messages
- 1,053
- Location
- Ohio
- Tractor
- Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
I am considering moving up to a 7520 from my 6000 4wd, and wondering if anyone else has done it, and if so, what have you found to be the major differences?
I have gotten use to my 6000 and know how it will handle loads, hills, etc. The 7520 seems to have a higher center of gravity, therefore wondering if it is more suseptable to tip over.
Also, wondering what my 6000 4wd with 400 hrs in good shape can expect to bring. It has canopy, rear wheel weights, front weights, grill guard, and loader with 72" bucket.
I have a 511 backhoe as well. Not many hrs on it at all. Do not think the sub frame from my 6000 will fit on 7520, and Mahindra shows it as different part number. But, should I sell the 6000 w/hoe, and buy a new one, or should I sell the whole unit? Does the 511 have a differenent set up now than they did with the early 6000, or would the switch over be easy? I do not have a pto pump and was told it is not available for the 7520 due to the high gpms of the 7520, it that true, and will it run the hoe at peak performance and not over heat the hyd fluid?
Also, does anyone know if my wheel weights on the 6000 will fit on the 7520?
Price of new 7520 about 23k and loader about 5100; great, good, or ok prices?
Thanks.
Thanks.
