Re: 4110 4WD problem After reading about this problem the other day I looked under my 4110 for the heck of it. The bolts on mine have metal tab washers under them from the factory - where you bend the tab up against one of the flats on the hex head - virtually impossible for them to come loose. My tractor was built in 2001. Maybe they quit using them since.
__________________ Mahindra 4110, FEL w/5' & 6' QA buckets & forks, 6' Atlas boxblade, 6' Howse rotary, Leinbach PHD w/9" & 12", 1 bottom plow, MF 2/3 bottom plow, 20"x6' bog disc,TSC subsoiler, TSC middlebuster, 6 ton Anderson 12' dump trailer, 20' Hurst 14k flat trailer. |
