Shirleyshusband
Must have been a bad weekend for tires! I knocked the tire off it's bead and also put a couple dents in the rim. Rocks! I lifted up the tractor in the field using the FEL. Got the bolts off (no easy chore, next weekend, I'm re-doing them all). Beat the rim back in shape with a wood block, metal block and sledge hammer. Got the tire back on the rim with two crow bars. Put (as simonmeridew did) a wratchet strap around the tire as tight as I could. Put air on it from my little pancake compressor. Then I just "tapped" the tire with a hammer while air was going in. It seated itself. Use CAUTION when removing the strap. I ran up 100 lbs of pressure to seat it good, tested with soapy water, hit the rim in a few spots again with the hammer to seal it better. Lowered the pressure to 45 and put it back on. Held air for two days with no leaks yet. I'll see what it looks like next weekend...
