09-15-2009, 08:42 PM
#11 (permalink)
| | Veteran Member
| Re: MF 165 vs. new kubota Quote:
Originally Posted by Farmwithjunk MultiPower simply gives you MORE options as far as gear ratios. MP is a "shift on the fly" hi/lo, where the 2-speed of the tranny requires clutching (and therefore, loss of drive) | Could also be called one of the first 2 speed powershifts, correct??
__________________ Thanks,
Will 04 GMC 1500 CC Z71 5.3L, 3:73 MF 1523, 1505 MMM, Wallenstein WX310 Log splitter, Kubota Turfbuster, Buhler-Farm King 50" Snow blower.
MF(FE)35 awaiting a resto.
MF 12 awaiting resto. http://dsdownham.com/Home.aspx |
09-16-2009, 12:56 AM
#12 (permalink)
| | New Member
| Re: MF 165 vs. new kubota well, i went and looked at the tractor tonight .. this is what I found out ...
>> it has 2997 hours on it
>> starts up fine, but the wiring to the alternator and ignition needs replacing as they are damaged
>> no oil leaks from the weep hole besides a small amount of engine oil
>> when we first started it, it did smoke a ton, but, after about 10 minutes it ran really clean - i am guessing all of the initial smoke was due to the sitting for 18 months
>> clutch went smoothly between low to high etc ...
>> i am not sure if it had a multi pto or not ... there was a lever on the left side of the dash that you could push up or down, moving the lever made no difference though?? this was on the opposite side of the fuel lever
>> the front left wheel wobbled pretty fierce when driving it, but, the mechanic i had with me thought it just needed new bearings??
>> brakes worked well
>> PTO started up fine and ran well, but, i had no implement to hook it up to
>> 3 point hitch would lift my 250 lb brother and hold him with no issues
>> there was an area in the front corner along the bottom of the engine block next to a bolt that leaked smoke and some oil when running?? bad gasket perhaps?? this one worries me??
>> turned easily to the left, but, very difficult to turn the wheel to the left
>> no stinger pump - that was the power steering cylinder
>> rubbers were definitely worn, but, in decent shape
>> one hydraulic lever (beneath seat) was frozen up and wouldn't budge - the other lever would move
all in all, the engine ran very well - I would still like to add a FEL to this tractor - could i use this one ?? massey fergunson front end loader heavy duty 6'bucket - eBay (item 300348000260 end time Sep-21-09 19:47:06 PDT)
also, how do you mount a FEL ... do i need to weld some custom mounts?? can you use the standard hydraulics on this tractor or am i better off adding a separate pump?? Thanks. |
09-16-2009, 05:57 AM
#13 (permalink)
| | Super Member
Originally Posted by gmacy well, i went and looked at the tractor tonight .. this is what I found out ...
>> brakes worked well
also, how do you mount a FEL ... do i need to weld some custom mounts?? can you use the standard hydraulics on this tractor or am i better off adding a separate pump?? Thanks. | That lever on the dash IS a MultiPower shifter. Did you shift it while the tractor was moving? If so, and nothing happened, the MP is on the fritz. Most likely, it'll be "stuck" in low range. Down side is, that'll let the tractor freewheel if you're going down a hill.
Steering issue is adjustable. Common ailment that's relatively easy to fix.
The loader you show will, for the most part, bolt right up. Internal hydraulic pump is "enough", but loader will cycle slower than some would like. Not a big deal unless you like to operate really fast.
The "area that smokes" sounds like the location of the engine breather tube. Not UNcommon to have SOME blowby. Oil from the breather tube would be alarming if it continues.
If you can, send me the serial #. It should be on a small metal tag located below steering wheel in front of shifters. That'll help determine year of tractor.
With year model, we can determine if the alternator is OEM or if it replaced a generator. That'll be helpful with re-wire. OEM alternator DOES NOT have internal regulator like most alternators today will have. Reg is under dash. Wiring is a little uncommon by "modern" standards. Service manual will have wiring diagram.
If you get this tractor, I'd HIGHLY recommend getting MF (oem) owners manual, service manual, and parts manual.
__________________ There are three kinds of men;
1.) The ones that learn by reading
2.) The few who learn by observation
3.) The rest of them have to pee on the electric fence for themselves. |
09-16-2009, 09:18 AM
#14 (permalink)
| | New Member
| Re: MF 165 vs. new kubota thank you for the reply ... the tractor does come with the manual, but, I was also planning on purchasing the video series from Big Dean as I have read many good things on them ...
as far as the hydraulic levers being frozen, is that simply an issue of flushing the fluid and working them out??
based on what i have seen, it seems like this tractor at 1200 is still a good buy?? |
09-16-2009, 10:08 AM
#15 (permalink)
| | New Member
| Re: MF 165 vs. new kubota on the FEL i posted, what is a fair price for that loader?? Thanks. |
09-16-2009, 10:58 AM
#16 (permalink)
| | Super Member
Originally Posted by gmacy thank you for the reply ... the tractor does come with the manual, but, I was also planning on purchasing the video series from Big Dean as I have read many good things on them ...
Hard to say about the hydraulic remote valves. I'm more inclined to believe there's something siezed because of rust.
I've seen those loaders sell for $1000 to $1500.
@$1200, it's a steal.
09-16-2009, 11:00 AM
#17 (permalink)
| | New Member
| Re: MF 165 vs. new kubota once more, i just really need to say thank you for all of the information!!
on the FEL ... does the 165 have the mounting holes standard for the FEL and you simply place and bolt the FEL on?? Thanks. |
09-16-2009, 12:45 PM
#18 (permalink)
| | Super Member
Originally Posted by gmacy once more, i just really need to say thank you for all of the information!!
on the FEL ... does the 165 have the mounting holes standard for the FEL and you simply place and bolt the FEL on?? Thanks. | The loader you linked will attach at the rear axles, via u-bolts around the axle housing, and the front of the loader frame will bolt to a mounting point under the tractor, just behind the bellhousing. There is a clutch inspection cover there also. You'll see 4 bolt heads under the tranny housing. Some MF loaders also attach at the mounting pads just behind the radiator, as part of the steering bolster frame. You'll see 4 threaded bolt holes on each side of the tractor there. That loader you linked is a very good loader in terms of what Massey offered.
09-16-2009, 01:01 PM
#19 (permalink)
| | New Member
| Re: MF 165 vs. new kubota thank you for the reply ... with a loader like that one, what parts could fail on it ... i.e. if the gaskets and hoses are in good condition, it is a simpler approach since I am using the tractor's hydraulic system, correct?? Thanks.
In addition, the seller of the FEL referenced 4 rams as opposed to 3 rams, what does that mean? |
09-16-2009, 01:09 PM
#20 (permalink)
| | Super Member
Originally Posted by gmacy thank you for the reply ... with a loader like that one, what parts could fail on it ... i.e. if the gaskets and hoses are in good condition, it is a simpler approach since I am using the tractor's hydraulic system, correct?? Thanks.
Look at the frame. If abused, they can crack. Usually the bucket will show signs of abuse if that's the case.
On occasion, some farm loaders had a single dump cylinder on the bucket (mounted in the center). That one has a pair.
That loader would be a VERY simple package since it's purpose built for that series tractor.
