Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. #31
    Veteran Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,183
    Etna, NH
    2005 MF GC2310 TLB
    Default Re: About to pull trigger on GC2400
    Actually, on the GC, it's not bad at all... there's little in the way in accessing the freeze plug --that's if, as I suspect, the 2400s are like my 2300. I know some of the larger tractors have something directly in front of the freeze plug that needs to be removed, but not so on the SCUTS, apparently. Mine went in very easily.
    I find it really handy that the power cord can be removed, so I don't have to worry about snagging it in the summer... and a standard garden hose cap can be used to cover it when the power cord's off.
    About to pull trigger on GC2400-block-htr-install.jpgAbout to pull trigger on GC2400-block-htr.jpgAbout to pull trigger on GC2400-block-htr-plug.jpgAbout to pull trigger on GC2400-cap.jpg
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, KK TYR-60 landscape rake, DR 60" Power Grader
    '05 VW Jetta Wgn TDI
    Numerous antique Japanese motorcycles
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #32
    Elite Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    3,806
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Default
    Quote Originally Posted by irvingj
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287940"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287941"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287942"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287943"/>
    Wow, that is easier. The fuel filter assembly is in the way, as well as wiring harness too.
    Thanks,
    Will
    I do not care if someone's net nanny is watching!! You need to stop...
  4. #33
    New Member
    Join Date
    Oct 2012
    Posts
    11
    Saskatoon, Saskatchewan
    Massey Ferguson GC2400
    Had a look and it's easily accessed on the GC2400. Just have to get over my nerves about popping out the frost plug on my new toy.
  5. #34
    Join Date
    Feb 2008
    Posts
    2,183
    Etna, NH
    2005 MF GC2310 TLB
    Piece a cake!
    Just follow standard procedure for removing a freeze plug (after draining coolant, of course)-- don't use a drill, or you may get metal shavings inside the water jacket. I used, IIRC, a drift punch on the edge of one side, to get it to rotate sideways, then a pair of Channel Locks to wiggle it free and pull it out. It'll be a lot easier if you remove the front grille piece-- at least that's the way it was on mine. WBB
Similar Threads
  1. Tractor Sizing About to pull trigger .......
    By GLT9007 in forum New Holland Buying/Pricing
    Last Post: 05-01-2011, 03:08 PM
  2. About to pull the trigger... I think?
    By Kipper76 in forum Buying/Pricing/Comparisons
    Last Post: 09-12-2009, 02:02 PM
  3. Pull the trigger
    By cag in forum Kioti Buying/Pricing
    Last Post: 08-04-2005, 10:29 PM
  4. should I pull the trigger?
    By pauld in forum Buying/Pricing/Comparisons
    Last Post: 10-10-2004, 05:10 PM
  5. About to pull the trigger
    By grayson1 in forum Zetor, Century & Branson
    Last Post: 12-20-2003, 11:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
