Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Jan 2009
    Posts
    51
    Waynesburg PA
    Ford 8n Massey Ferguson 255 Massey Ferguson 265 NEW!!! Mccormick CX75
    Default Looking at a Compact tractor to mow with
    Looking for a good tractor to mow my grass with either a rear pto finish mower or a mid mount. A must for me is that it will handle at least 72" (6') finish mower. I currently use a 8N with the 6' finish mower but im tired of issues always coming up with it. I will not be putting a loader on it, just the mower. I already have a 75 horse farm tractor for my loader tractor and that i do everything around the farm with, im just simply looking for a grass cutting tractor. Not sure what HP i would need and also not sure about these tractors, wanted to hear from people that have had them for awhile. Ive narrowed it down between LS and massey ferguson. Any info anyone can give me would be great about the size i should get, HP and how you like yours would be great!
    Thanks
    Taylor
    Sell, buy used equipment and implements. Also stock many parts!
    Current college student at Marietta College
    My Personal Fleet!
    *2006 Dodge 2500 Cummins Turbo Diesel
    *2005 Delta 25' Gooseneck
    *2005 McCormick C70
    *1952 Ford 8N
    *1946 Farmall BN thinking of trading for A
  2. #2
    Gold Member
    Join Date
    Mar 2005
    Posts
    394
    The Real Central PA
    BX25D, JD 820
    Default Re: Looking at a Compact tractor to mow with
    Have you considered a zero turn mower?
    If ignorance is bliss, then why aren't more people happy?
  3. #3
    Veteran Member fordmantpw's Avatar
    Join Date
    Mar 2013
    Posts
    2,001
    Central MO
    John Deere 2720
    Quote Originally Posted by coveredbridge View Post
    My thoughts exactly! If it is a dedicated mowing machine, and you are sure that is all you will ever use it for, then I think your money would be better spent on a ZTR instead of a compact tractor.
  4. #4
    Super Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    5,061
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Default
    Get a rear finish mower, and either a 1635 powershuttle, or the new 1700 equivalent.
    Once you have the second smaller tractor, you will have other work for it.
    Ever consider a cab?
    Thanks,
    Will
    2017 Ram SXT 1500 Crew Cab 4x4 5.7 Hemi 6 speed auto.
  5. #5
    Join Date
    May 2005
    Posts
    669
    SE Indiana
    Ford, Kubota, Massey Ferguson (Never Again)
    If you have only true finish mowing jobs for this tractor, your land is relatively flat, and you have no other significant jobs to use with the 8N replacement, buy a ZTR.
    Otherwise, post back.
    SDT
  6. #6
    Join Date
    Jan 2009
    Posts
    51
    Waynesburg PA
    Im sure I would find other things to do with it besides mow, and i like the idea of a tractor more than a zero turn. never really looked at them tho, can you get a 6ft deck on a zero turn?
    My Personal Fleet!
    *2005 McCormick C70
    *1952 Ford 8N
  7. #7
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,905
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by tmiller View Post
    You can get a 6ft deck, or larger, on a front deck mower. If you have a large area to mow, it is the best way to do it. If it is hilly, get a four wheel drive.
    Looking at a Compact tractor to mow with-p5250004-jpg Looking at a Compact tractor to mow with-p5250008-jpg Looking at a Compact tractor to mow with-p5250011-jpg Looking at a Compact tractor to mow with-p5250014-jpg
    Check this thread: http://www.tractorbynet.com/forums/k...-f-series.html
    72 front deck mower | eBay
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
  8. #8
    Member
    Join Date
    Aug 2013
    Posts
    37
    Fayette, AL
    LS XR3037 & Kubota BX25D-1
    Get a zero turn mower. You can mow circles around a tractor with a finishing mower.
  9. #9
    Join Date
    May 2004
    Posts
    5,061
    Default
    Quote Originally Posted by AdamCanterbury View Post
    And that is all you can do. Just too much money for limited use.
    Get the tractor, higher return on investment since it is a 12 month machine.
    Thanks,
    Will
  10. #10
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Default
    My decision would be made if I where in your shoes is sell the small ford tractor and start shopping for a commercial grade ZTR. The commercial grade cost considerably more but dependability goes way up the bar with them. Most pro cutter are sixty inch. You can. Go wider but then again so goes the price. A six footer would still be less than a newer mini tractor with a mid mount. I also would think that fuel usage would be less due to the fact the work could be done in quite a bit less time. It also depends how much lawn or pasture your cutting to justify the cost. I cut 4.5 acres every week with a 54" ZTR hoping one day to upgrade to a 60"+ deck. Mine is a commerical grade mower and it's worked well for the last twelve years.
Similar Threads
  1. Replies: 41
    Last Post: 09-11-2015, 12:57 PM
  2. What to use where the tractor can't mow?
    By suttles in forum General Lawn & Garden
    Last Post: 07-09-2006, 05:46 AM
  3. How fast can you mow w/ a compact tractor?
    By nate22 in forum Buying/Pricing/Comparisons
    Last Post: 03-21-2006, 12:08 PM
  4. New Compact / sub Compact Tractor Purchase
    By Bricklin in forum Buying/Pricing/Comparisons
    Last Post: 11-20-2005, 09:49 PM
  5. To mow or not to mow septic drain field
    By adlertom in forum Rural Living
    Last Post: 09-01-2004, 11:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
