I just purchased a 70's 135 yesterday and had it serviced. It runs fine but there is some concern with the oil pressure. The pressure was at the top of the gauge after it was serviced for a while and then dropped to half way. it holds steady at the half way mark but drops to 1/4 (just above the red line) at idle when hot. We put it through its paces and it bush hogged fine and the pressure held steady. It preformed very well.
can you tell me where your pressure gauge runs? I have had several people say its just old and thats normal and one other said I need a new crankshaft another said it needs new bearings. I don't know much about tractors and am trying to get some advice on what to do. The tractor will only be used for food plots and bush hogging so it shouldn't see a ton of use.
Another question. Since this tractor hadn't been used for a couple of years, is it possible some junk is blocking the flow causing the pressure to drop? There doesn't appear to be any leaks.
To summarize my questions:
1. Where does your oil pressure run at full speed and idle
2. Does this sound normal
3. My guage does not show PSI, do you know what the PSI range is on a 70"s 135
4. If this isn't normal, any idea what the issue is
I am running rotella 15/40
Thanks
Thanks
