Results 1 to 3 of 3
01-27-2010, 10:36 AM #1New Member
- Join Date
- Jan 2010
- Posts
- 1
1971 MF 135 rebuild problem - missing bolt
All,
I'm rebuilding a 1971 MF 135 with a Perkins Gas engine. I'm into final assembly and realized that the new water pump I ordered did not come with the long bolt that would go on the lower right side of the unit (behind the pully). Does anyone know the correct size of this bolt and the thread type? I'm stuck without it. I'm sure this is a n00b question but this is my first time with this type of work.
BTW - I checked with the vendor and they don't carry them or know what size it is.
Thanks
01-27-2010, 12:18 PM #2
Re: 1971 MF 135 rebuild problem - missing bolt
5/16 x 3" coarse thread. should be able to get about anywhere.
01-28-2010, 09:19 AM #3Gold Member
- Join Date
- Sep 2008
- Posts
- 336
- Location
- Manvel Texas
- Tractor
- Ford 1700 2cyl, Ford 1600 2cyl Massey 135 3cyl gas
Mfred is correct, here is a picture of my old pump. The bolt is still in the pump. Can you post some pictures of your progress? I have the same year model, and motor, doing the same thing. My motor is now together and running, but put the project as a whole on the back burner for a couple of months. How extensive of a motor rebuild did you do? Thanks, TB
Similar Threads
Power Steering Problem Not Solved
By Alan L. in forum Kubota Owning/OperatingReplies: 87Last Post: 03-31-2011, 06:35 PM -
MF 135 Wiring help needed
By madmrallysport in forum Massey Ferguson Classic/VintageReplies: 5Last Post: 05-03-2009, 12:23 PM -
MF 135
By madmrallysport in forum ProjectsReplies: 1Last Post: 04-01-2009, 10:39 AM -
JD 4000 series wheel bolts
By Anonymous Poster in forum John Deere Owning/OperatingReplies: 5Last Post: 04-13-2002, 10:56 AM -
Chain of command
By Anonymous Poster in forum John Deere Owning/OperatingReplies: 9Last Post: 04-13-2002, 06:17 AM
