Results 1 to 10 of 12
03-11-2010, 09:09 AM #1New Member
- Join Date
- Mar 2010
- Posts
- 7
Massey 135 Lift Problems
I just purchased a massey 135 and I believe there is something wrong with the 3 pt hitch. The tractor does not have any remotes. The position lever does not have any response on the lift moving up and down. The only way the lift will move up is if I move the draft control to the highest position and if you move the draft control down any the lift falls. It seems like the position lever moves more freely than it should. Could it be that the position lever is stuck in the highest position? Is there something on the lever itself that could have broke? Thanks
03-11-2010 09:09 AM # ADS
03-11-2010, 10:07 AM #2
Re: Massey 135 Lift Problems
The linkage is probably disconnected in the bottom of the housing there is a 10cent clip that breaks or falls off it's a PITA to put in but you don't have to pull the top cover,get an IT shop manual and you will see where it goes.
I have replaced them before by removing the left cover that the slow-fast lever and the other side that holds the pto shift lever.
03-11-2010, 10:50 AM #3New Member
- Join Date
- Mar 2010
- Posts
- 7
I ordered an I&T manual today so I should have it in week or so. Does anyone have pictures or diagram of this clip you could post of email to me. Thanks
03-11-2010, 10:59 PM #4
03-11-2010, 11:45 PM #5Platinum Member
- Join Date
- Aug 2003
- Posts
- 842
- Location
- Eastern North Carolina
- Tractor
- Mahindra 2810HST
Another poster told of the roll pin through the base of the control handle failing, as referenced by part #25.
_________________________________________________
03-12-2010, 08:34 AM #6New Member
- Join Date
- Mar 2010
- Posts
- 7
Thanks for posting the diagram, I think my control might be different than yours. Mine has about a 12 in shaft spacing the levers out from the tractor. Does your have this also?
03-12-2010, 01:09 PM #7
03-12-2010, 03:16 PM #8New Member
- Join Date
- Mar 2010
- Posts
- 7
That looks the same as mine. thanks for posting the picture
03-20-2010, 11:15 AM #9New Member
- Join Date
- Mar 2010
- Posts
- 7
I tore into the tractor and the return spring for the position lever was in the bottom of the tractor. I cant find where the pin goes?
03-21-2010, 11:54 PM #10New Member
- Join Date
- Mar 2010
- Posts
- 1
- Location
- Indiana
- Tractor
- 1972 MF 20 Industrial w/MF 32 Loader
Hey there Flusher - good looking rear tires on that 135. I'm looking to upgrade my MF20 Ind. tires to something wider. What have you got on yours?
Similar Threads
Breaking in my new toys... from Yeehaw! to Uh oh!
By Spiveyman in forum Owning/OperatingReplies: 344Last Post: 10-27-2010, 10:29 PM -
Massey 135
By moggie4000 in forum Massey Ferguson Classic/VintageReplies: 5Last Post: 11-24-2009, 07:57 AM -
Conversion Factor for 3PH load capacity
By datanull in forum Buying/Pricing/ComparisonsReplies: 73Last Post: 06-11-2009, 07:51 PM -
MF 135 lift problems. help
By pharmvet in forum Massey Ferguson Classic/VintageReplies: 4Last Post: 05-29-2009, 07:24 AM -
Lift height problems with KK rake on B2620
By seapea in forum Kubota Owning/OperatingReplies: 26Last Post: 03-19-2008, 11:17 AM
