Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jun 2011
    Posts
    1
    Massey Ferguson 135, Diesel
    Default Massey Ferguson 135 Diesel head torque
    I am replacing the head on my massey 135 perkins diesel but cannot locate head bolt torque pattern or specs. Also I will also need the torque specs for the valve rocker rail. Any other advice will be appericiated.
  2. #2
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,409
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Default Re: Massey Ferguson 135 Diesel head torque
    Quote Originally Posted by wallyb147 View Post
    Here's the info you need:
    Massey Ferguson 135 Diesel head torque-ad3-152-head-bolts-small
    Head bolt torque is 55-60 ft-lb.
    The service manual doesn't list torque specs for the rocker arm. Just says to progressively tighten the support nuts EVENLY, until they are securely tightened. Looks like you're on your own here.
    BTW: I have a 1964 MF135 diesel deluxe with multipower.
    Good luck
  3. #3
    Join Date
    Jun 2005
    Posts
    7,409
    Sacramento
    Forgot to mention--I recently installed the head on the 4-cyl Hercules IXB3SL engine in my 1951 Minneapolis Moline BF tractor, a 25 hp gasser. Most of the holes for the head bolts connect to the cooling passages in the block. So you need thread sealer on the head bolts--I used that Permatex white sealer with Teflon.
  4. #4
    New Member
    Join Date
    Dec 2011
    Posts
    1
    MF 135
    Your drawing shows a washer on bolt # 15 as does my manual. My head didn't have one & I'm about to put the head back on. What & why one washer please?
  5. #5
    Member
    Join Date
    Sep 2011
    Posts
    46
    North America
    MF
    Not knowing the year of your tractor, it is hard to say, but it is my opinion that the early Perkins diesels had the washer. It was deleted on the later models, but I do not know the date. Min is a 1974 and the washer was omitted by the MFR.
    Good Luck.
Similar Threads
  1. 1962 Massey Ferguson 50 input needed
    By Saggydog in forum Massey Ferguson Owning/Operating
    Last Post: 05-31-2012, 08:43 PM
  2. Oil & Fuel Where to put oil in massey ferguson 135?
    By wegge in forum Massey Ferguson Classic/Vintage
    Last Post: 10-15-2009, 09:45 PM
  3. Oil & Fuel Diesel additive or not?
    By Jeffery8mm in forum Mahindra Owning/Operating
    Last Post: 05-14-2009, 10:54 PM
  4. 231 Massey Ferguson
    By Travis_R in forum Massey Ferguson Owning/Operating
    Last Post: 07-17-2007, 11:17 PM
  5. Oil & Fuel Diesel torque difference mostly myth?
    By getut in forum Owning/Operating
    Last Post: 04-26-2005, 12:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
